Without a wheel chock!
Old Jun 3, 2009 | 01:31 AM
Yamhill Guy's Avatar
Yamhill Guy
I've trailered a couple bikes in both an open trailer and enclosed trailer. In the open trailer, I found it worked best when I could get the strap hooked onto the frame. Trying to cinch down on one of the tie downs screwed to the side of the trailer resulted in the tie down coming off.
I also always engage first gear. It shouldn't make any difference since the bike shouldn't move anyway, but it makes for better peace of mind.
Old Jun 3, 2009 | 12:22 PM
gmc's Avatar
gmc
Your friend must have a way to secure the front tire, strap to front rail etc. You don't want the tire turning or slipping sideways. Does it have a wood floor, if so you can cut a 2/4 and screw one on each side then stack another on top for a cheap fix. HF also has a inexperienc wheel chock.
Old Jun 5, 2009 | 03:01 AM
xxxflhrci's Avatar
xxxflhrci
I dont' use a chock and don't strap the front wheel to anything. I have never had the front tire turn sideways in thousands of miles of bike hauling.
Old Jun 5, 2009 | 04:26 AM
BillyG0856's Avatar
BillyG0856
Here's a couple of ideas for ya. As mentioned above, you could buy a wheel chock...use it on your trip, then 'donate' it to your friend for his use. Or, you could buy the chock....mount it to a 'square' of 3/4" plywood....lay or mount it on the trailer for use...then remove it when your finished.
I have this chock from Harbor Freight....and my buddies and I have bought an extra to keep @ work. Harleys, Valkryes, VTXs, Kawasaki, BMW....Works GREAT!!!
Good Luck!!
Billy G
Old Jun 5, 2009 | 04:31 AM
electricstart's Avatar
electricstart
I would go with chock or make sure you block front wheel in some how. These guys are right chocks are cheap enough.
bagger51
25
Feb 21, 2017 10:11 AM
InMotionJosh
Jul 14, 2015 08:05 AM
TedMan
Apr 17, 2009 04:40 AM
harley_nova
General Topics/Tech Tips
Jun 4, 2008 12:03 PM
mtdrop
Apr 16, 2008 02:02 PM
