I tend to use farthest forward setting for longer trips, as that gives the best support, then switch to farther back, just to change positions and stretch a bit. For short trips, I use the "in between" setup.
Okay, I've been drinking and all, but what kind od freakin' question is this?
i'm currently stuck in "all the way back" because the backrest I have has a broken shock. I'm trying to determine if it's worth the $150 HD wants to replace the shock and bracket. I'm currently talking with the shock maker to see how much a replacement shock is. I'm considering making a tie rod sort of contraption to have an adjustable, locking setup so i can find the one I like.
Front to back changes with conditions...length of trip. Up & Down, at times....I'll lower it. Most times, it's all the way up. That's the nice part about 'adjustable'.....
I have the HD adjustable...and often find the little 'pocket' on passenger's side comes in handy....insurance card, ciggies, xtra lighter, headset cords, etc.
