Lesson Learned
Old Jun 7, 2009 | 06:10 PM
Yachtman's Avatar
Yachtman
That gas on the floor is going to get slick if it gets wet?............ No??
Old Jun 8, 2009 | 07:34 AM
mainshaft's Avatar
mainshaft
Thank god the bike didn't fall on you. OUCH.
Old Jun 8, 2009 | 08:12 AM
Our07Ultra's Avatar
Our07Ultra
Originally Posted by emwolb
if you're planning on doing maintenance at home, you might wanna get a floor jack for motorcycles. i use the aluminum yellow craftsman, and i like it. it will sit your bike upright for just such work. it's been very useful around my shop.
+1
Very handy and stable.
Old Jun 8, 2009 | 11:05 AM
PDDGM's Avatar
PDDGM
Yes I feel very lucky, I had just gotten up to go to the bench to get a rag. Drained and refilled the primary with 32 oz. So all is good, rode bike for about an hour last evening and nothing was wrong. Guess the fall didn't hurt anything. Thanks to all. I have put a lift(jack)on my fathers day want list, also a front wheel chock.
joe
Old Jun 8, 2009 | 12:27 PM
07RoadHawg's Avatar
07RoadHawg
Originally Posted by PDDGM
I had the bike standing straight up as the manual says, If I had it on the jiffy stand it wouldn't have fallen over and yep a qt would have most likely filled it up. So I should go drain out the oil and fill it on the jiffy stand not standing straight up as the owners manual says. Thanks for the info.
Joe
My manual (2007 RK) says 38oz for a wet primary change and 40-something for a complete change, so you probably had it right the first time. Takes about 38oz to see fluid at the bottom of the clutch basket when bike is upright, just like in the book. I typically do what the manual says and not so much what I read on the net. FWIW...
Old Jun 8, 2009 | 12:56 PM
HDRider2002's Avatar
HDRider2002
The gas was probably from the fuel overflow, when the bike was on its side i'm sure it sloshed some gas up through there. happens all the time when you tip the bikes, or even if you over fill them at the pump. Glad nothing and no one was hurt!
Old Jun 8, 2009 | 01:55 PM
FastHoss's Avatar
FastHoss
Hey Rook Daddy,get a jack
Synstars
May 30, 2017 07:54 PM
slowrollin
Nov 2, 2015 02:49 PM
BigDaddyMongo
Jun 6, 2011 11:30 AM
magnum629c
Mar 20, 2010 08:42 AM
Valkyrie
Nov 30, 2007 08:33 PM
