Clutch Issues.??
Old May 19, 2006 | 07:06 PM
XRP's Avatar
XRP
Default RE: Clutch Issues.??
Mine has done that since new. April 06, have about 3000k on it. Only serviced at the dealer. I thought it was normal. Only in first gear also.
Old May 19, 2006 | 07:31 PM
Bryan TTM's Avatar
Bryan TTM
spring pressure not equal....pressure plate with abberations on it(warped or uneven machine work)...plate or plates coming apart....steels with hot spots...adjusted to tight(when it warms up things expand and want to drag, that will create hot spots on the steels and they promote chatter & slip)...improper oil fill...improper oil...plates & steels not fully seated in the basket...
take it apart and look...clutches are real easy
an out of adjustment clutch that causes grabby or chatter starts will hot spot .
Old May 19, 2006 | 07:41 PM
jeepster09's Avatar
jeepster09
Install a VPC pressure plate and you will get better clutch action,an easier pull at low speeds and longer clutch life!
http://www.harleyhog.co.uk/hippovpc.htm
Old May 19, 2006 | 08:06 PM
Bryan TTM's Avatar
Bryan TTM
jeep...can you explain the VPC and what it does to me please....i read the link....does it increase clamping force or just a fancy easy pull
Old May 25, 2006 | 08:54 PM
jeepster09's Avatar
jeepster09
It increases clamping force and makes the pull easier. It has centrifical weights that increase pressure with rpm. It will increase your clutch life and eliminate slippage. Sorry didn't answer sooner been out of town.
Old May 25, 2006 | 11:36 PM
g money's Avatar
g money
Account Retired
My 06 Roadglide has done the exact same thing since 200 miles. Still does it now with 2200 miles. Dealer said its normal.
Old May 26, 2006 | 01:00 AM
Spartan's Avatar
Spartan
It's either a warped pressure plate or weak disc springs......
Old May 27, 2006 | 12:20 PM
g money's Avatar
g money
Account Retired
Since this only happens when hot, i guess we can eliminate weak disc springs, right?
Old Jun 6, 2006 | 06:05 PM
g money's Avatar
g money
Account Retired
Yota,
Did you ever get this figured out?
Gary D.
Old Jun 6, 2006 | 06:22 PM
yota's Avatar
yota
Hey Gary, read my other post and u will see that the dealer has got me in a spot..Yesterday they were giving me the bike back fixed but was not and other issues now unsolved..GRRRRRR
