Hog tunes amp install-no power
Old Jun 29, 2009 | 05:30 AM
bcerame's Avatar
bcerame
5th Gear
Default Hog tunes amp install-no power
Any ideas on what I may have missed?Spent a couple of hours yesterday installing Hog tunes speakers\amp on my '09 SG. Watched the HT video and followed written manual to the T. Can't get the amp to power up. There is a small status lamp on one side and it won't light up. I reinstalled the wiring harness 3 times and still no luck. There is a fuse in the amp head but I can't figure out how to get it out to check it. Bought this brand new from Dr VTwin.
Old Jun 29, 2009 | 06:00 AM
Ribitt's Avatar
Ribitt
Cool
ensure your batter connection is good. I had to reattatch the ground wire. also make sure your cig lighter fuse is good.
Old Jun 29, 2009 | 07:41 AM
Badbagger's Avatar
Badbagger
Check your fuse BUT the most likely culprit is a ground and obviously check battery connections.
Old Jun 29, 2009 | 09:12 AM
bcerame's Avatar
bcerame
5th Gear
Default hog tunes amp
Thanks. The lighter is hot and I connected-disconnected the ground to battery wire 3 times. That leaves the fuse. Next step is contact HT I guess.
Old Jun 29, 2009 | 03:09 PM
robandlyn's Avatar
robandlyn
Just call PEZ and he calls right back !
Rob ....
Old Jun 29, 2009 | 11:51 PM
rideshack's Avatar
rideshack
Former Sponsor
Check to make sure there is a fuse in the fuse holder near the battery connection. We have seen some harnesses shipping without the 7.5 amp MINI ATO fuse and we have begun checking the kits before they ship to the customer. Also, check to be sure you're getting +12 volts from the orange wire at the amp connector. It not, the "Y" connection at the cig lighter could be bad. Good luck.
Corey
Old Jun 30, 2009 | 12:58 AM
iaglide's Avatar
iaglide
Stage III
hi i installed same amp and speaker set up a month ago in along with the there tweeter set up.i bought this from eastern performance and had questions.i called pez at hog tunes.turns out they had a few of these get out with the wrong harnesses.he sent me the correct harness over nite and they sound great.give them a caal great people to work with ive installed several sets.
Old Jun 30, 2009 | 05:05 AM
bcerame's Avatar
bcerame
5th Gear
Default issue solved
I contacted PEZ and we figured out that it was a fuse missing out of the holder. Also, they are shipping me a new power plug for the amp. Great follow up from them!
Old Jun 30, 2009 | 07:24 AM
mainshaft's Avatar
mainshaft
+2 on calling them, very helpful, sent me the correct harness over night as well. Great folks.
RickK
Audio Systems
Apr 29, 2018 04:51 PM
doctorgoo
Audio Systems
Mar 12, 2018 09:00 PM
E8USMCRET
Audio Systems
Apr 24, 2017 11:29 AM
decencyxdefied
Audio Systems
Jun 8, 2016 11:54 AM
kryingame
Audio Systems
Aug 10, 2014 07:27 PM
