Sundowner seat warning!!!!
Old Jul 21, 2009 | 07:44 PM
rides99fatboy's Avatar
rides99fatboy
Originally Posted by 1931jamesw
Well...I picked mine up today and just installed it. I loosened those two bolts your talking about and used blue locktite (stick type) on them and put it back on. I hope this holds it. It says right next to those bolts not to loosen them. It says something to the effect that these bolts are factory tighten do not loosen. The material that they screw into seems like plastic. Will the locktite work on plastic?
My issue was not because the bolts backed out, it was because my wife sitting on it pushed the seat down enough to make contact. I had to grind the raised edges on the hex screw down smooth. I left about 1/16" of screw head which was enough to screw them back in.
And my wife is about 145 lbs, so not just from her weight. Probably from hitting bumps and her bouncing up and down putting more pressure on the back of the seat.
Old Jul 21, 2009 | 07:45 PM
Primo's Avatar
Primo
Here's is what seems to be good prevention BEFORE it happens.
Too late for the OP and myself though.
http://stoneystraps.com/products-details.php?id=35
Old Jul 21, 2009 | 07:48 PM
1931jamesw's Avatar
1931jamesw
AAHHHHH....now I see!
Old Jul 21, 2009 | 09:57 PM
QIKLUV's Avatar
QIKLUV
OK starting the rapairs this weekend... does anyone know the paint code for the 09 SG Black Pearl.
and what would be a good solo seat??
Old Jul 22, 2009 | 03:41 AM
riteway's Avatar
riteway
Man that sucks....1st thing i check tomorrow!!!! I love my sundowner!!!!
Old Jul 22, 2009 | 10:25 AM
smittydog27's Avatar
smittydog27
Default my fix
I noticed the same problem a few months back on my RG with a Sundowner. I used the Lanka (sp) paint repair for the paint scratches. After that, I got a felt furniture tab (multi pack) and put one on the offending bolt head. It was slightly larger than the bolt head and it had a 'sticky' adhesive that attached it to the bolt head. No more paint marring.
Old Jul 22, 2009 | 10:37 AM
crewchief25's Avatar
crewchief25
I put a 08 SE Road King seat on my Glide and noticed the same thing. I replaced the bolts with pop rivets, and put 3M clear film on the fender.
StuBerger
Jun 3, 2012 12:13 AM
stonesmith
Jan 4, 2011 02:49 AM
nedster
Jun 6, 2010 10:49 PM
kawsakimx6
Jun 21, 2007 05:21 PM
manowar
Jul 17, 2006 07:40 PM
