Rims from FLHX ON E-Glide Standard
Old Jul 23, 2009 | 12:46 PM
John M.'s Avatar
John M.
6th Gear
Question Rims from FLHX ON E-Glide Standard
Hello All
i Need Help.
do the Rims from a 2008 FLHX fit on my 2005 E-Glide Standard ?
maybe somebody knows ?
Thanks from Germany
John
Old Jul 23, 2009 | 12:50 PM
rocknrod's Avatar
rocknrod
You would have to make sure the bearings in the 08 wheel are changed.
Old Jul 23, 2009 | 12:57 PM
leohd's Avatar
leohd
06/07 street glide would fit 08 has different bearing size
Old Jul 23, 2009 | 01:53 PM
huffhuff's Avatar
huffhuff
any bearing shop will have bushings to adapter smaller diameter axles to larger bearing holes if that's the case here.
Old Jul 23, 2009 | 04:21 PM
GzrGlide's Avatar
GzrGlide
You'll need new bearings in those wheels. Meaning smaller ID.
I put SG wheels from an 07 SG on my 02 with no problems. But I think in 08 they changed the axle sizes ( the rear one for sure ).
Old Jul 23, 2009 | 04:33 PM
Coolhawg6622's Avatar
Coolhawg6622
Yup they will fit as long as you change the 25mm bearings to 1" bearings.............
Old Jul 23, 2009 | 05:57 PM
jag1886's Avatar
jag1886
I put 08 wheels on my 07, all you need is a new set of bearings just like everyone here says.
Old Jul 24, 2009 | 10:13 AM
emwolb's Avatar
emwolb
don't forget that the 08 also was the first year to use the isolated drive system. I.D.S. that may also make a difference. your 05 didn't have the i.d.s.
Koi1975
Oct 2, 2012 12:19 PM
SA315B
Feb 24, 2011 10:01 PM
fathertime
Oct 5, 2008 06:49 AM
legman55
May 26, 2008 08:26 PM
asuperheat
Aug 26, 2007 07:58 AM
