SERT vs. PClll vs. Fuelmoto
1. Does the PClll have more flexibility than the SERT?
2. What experiences does anyone have with the Fuelmoto?
3. I have an '05 RK Classic with the stage one download, K&N filter and Thunderheader slip-ons - not true dual. Does the SERT and PClll have pre-programmed maps in them where a person can select these basic mods and just program them in? As close to stock as mine is, I was wondering if you really need to spend the money for a tuner and dyno to take a few passes - or just program it yourself.
Just checking on the value of spending the money on the dyno and tuner labor - I'm frugal too!!!!! But more importantly I share a check book with the wife!
So answer to
#1. No
#2.Me-none (sorry)
#3.No-SERT must be done by a tech or someone with knowledge of SERT program. PCIII can be tuned from your laptop and there are maps on the internet at the PCIII website, but nothing is actually per-programmed into the unit. Again, Fuelmotousa will pre-program it for you.
And lastly, you can get by without a tune if you have a proper map, but the dyno tune will make a big difference.
Been reading posts and had a few Q's -
#1 No.... SERT is an ECM Program modification Tool, where you ACTUALLY manipulate the data inside the EPROM...... SERT has more tuning TOOLS available to it within the Advanced Mode of programming....
PC is an Inline Piggy Backed Signal Modifier (Modem) that manipulates and modifies the real signals to and from the ECM....
#2. Installed a few PC's from them that customers brought to us..... Maps were ok... Driveable for the most part.....
#3 SERT has HD maps that once you load it, you can manipulate the data to tune in your needs or to modify certain parameters that are not beneficial to the performance (or lack of)......
PCIII is the same concept, just not as many tools to utilize, but a Huge library of "Canned" Maps...
No matter, you are going to want MORE out of it, so yes, you will need to tune it..... And if you mess it up, you revert back to the previous config.....
Or you pay someone to do it... your call on that......
Frugality has nothing to do with it.....
How much is that Top Notch Performance worth?
JMPO....
So, any before and after stories out there on fuel economy?
