which is the louder pipe?
Old Aug 4, 2009 | 10:27 AM
Gordon65's Avatar
Gordon65
Default which is the louder pipe?
monster ovals, or the jackpot dyno tuned ones.....
thanks!!!!!!!
Old Aug 4, 2009 | 10:47 AM
catracho's Avatar
catracho
Thunderheaders!!
Old Aug 4, 2009 | 10:51 AM
Gordon65's Avatar
Gordon65
of those two......
Old Aug 4, 2009 | 11:10 AM
Errk08's Avatar
Errk08
so if i get jackpots will i have to get a ecm?
Old Aug 4, 2009 | 11:29 AM
FLHTCU Owner's Avatar
FLHTCU Owner
Depends on whether you're talking about just slip-ons, or true duals. Just slip-ons, then you don't need an ECM, or a re-map. If you go with TD's, then yes to the ECM AND a high performance breather. JMO.
Old Aug 4, 2009 | 11:36 AM
FLHTCU Owner
[QUOTE=Gordon65;5373548]monster ovals, or the jackpot dyno tuned ones.....
thanks!!!!!!![/QUOTE
I don't have either, but have heard both. IMO, the Jackpots are louder in terms of decibel levels, the MO's are 'deeper' sounding.
There's enough running around with both, recommend giving a personal listening before getting either.
Old Aug 4, 2009 | 11:56 AM
Gordon65's Avatar
Gordon65
[quote=FLHTCU Owner;5373921]
Thank you for the reply!
i will try and find some to listen to, but will probably go with Screaming Eagles then. I want to place a fuelmoto order soon, and was thinking of going with their package.
I don't want a pipe much louder (or any louder) than stock, so if the jackpots are louder than the monster ovals, i don't want them.
Old Aug 4, 2009 | 12:34 PM
Errk08's Avatar
Errk08
if i go with slip on's what am i gaining/losing?
Old Aug 4, 2009 | 12:56 PM
FLHTCU Owner
[QUOTE=Gordon65;5374032]
Check with Jamie at FuelMoto first as he probably has the decibel rating for the Jackpots. You can compare that to the Monsters and judge for yourself. Like I said, it's just my ears and opinion so don't take it for Gospel.
I would never choose pipes based on someone's statement, as everyone hears differently and has different expectations. Certainly not without hearing them first. Take your time and give several a listen before buying. You can probably attend 1 Bike Nite in you're location and be able to listen to all you're considering. Might even hear some you like that you weren't considering. There's SO many, it can get confusing.
Old Aug 4, 2009 | 01:01 PM
FLHTCU Owner
Nothing, other than 'sound'. Most go with different mufflers because they don't like the stock sound. It's the quickest and most inexpensive way to change the sound on a stock bike.
