Need a little extension help
Old May 29, 2006 | 01:32 PM
Bigdaddy331's Avatar
Bigdaddy331
6th Gear
Default Need a little extension help
I have a 2001 Electraglide. I'm also 6'10" and need to do something about my leg position. I would like to extend and tilt the floorboards on both sides. Anybody have any ideas on how to do this. Actually, my first question: 1. Is there an aftermarket company that sells parts for this? 2. I can fab just about anything... mig, tig, steel, aluminum... etc. etc. Anybody ever do this before? It would be great to get a pic or an idea.
Thanks in adavance.
Old May 29, 2006 | 05:06 PM
bountyhunter's Avatar
bountyhunter
Default RE: Need a little extension help
Throw down for a set of Kuryakyn Cruiseboards for the crash bar and get extended pedal and shift arms. Another option would be www.accutronix.com extended forward controls, very cool!
Old May 29, 2006 | 05:53 PM
Bryan TTM's Avatar
Bryan TTM
i had the same prob...i took the boards off and fabbed a half inch spacer and got longer bolts...now i'm figurin on how to move em forward...the 1/2" out really helped tho...if you look at the bottom of the board pan i spose you could put the braces on the backside of the groove...the rear one would stick out tho...or you could cut the bracket close to the pan and weld an extension in there...you'd just have to paint or powdercoat it...the day i had em off and was lookin, the welder was out of gas or it'd be done already
Old May 29, 2006 | 05:59 PM
Bigdaddy331
6th Gear
I'm thinking that I'd like to fab something in the 3 inch range and with the front of the board tilted up a bit. Also might fab up some rods that your heal can rest against. I know that there is an extended break arm and that it's also adjustable. That may be in order as well.
The biggy on the right side is the break resevoir. I'll have to come up with something. Powder Coat won't be a problem, as I do it myself. The Left sid will be less tricky (I hope) because the shifter arms can be lengthend and shortened respectively. Maybe I'll do it and post some pics so that other freaks of nature can see what to do.
Anybody else got any ideas???
Come on... help a brother out.
Old May 29, 2006 | 07:45 PM
Beemervet's Avatar
Beemervet
I am 6' 5", and used extended brake, shifter, and floorboards from Bubba's Brake. 2" forward. Quality stuff. There is a tilt adjustment for the floorboards on baggers. I also have a Corbin solo seat that moved me back and down. Pegs mounted low on the engine guard. Different bars from Wild 1 on my RG completes my "vertically gifted" adjustments. Lowers are not an option. I'm very comfortable, but my mech. has to sit up on the rear of the tank to test ride my bike.
Old May 29, 2006 | 09:43 PM
Bigdaddy331
6th Gear
That's exactly the info I wanted... I'll check out Bubba's Brakes. Might be just what the doctor ordered.
Thanks for the info Beem!
Old May 29, 2006 | 10:34 PM
Beemervet's Avatar
Beemervet
http://www.bubbasbrake.com/footboard.htm
Pricey stuff, but high quality. What price do you put on comfort? Depends on how old you are.
Old May 29, 2006 | 11:11 PM
UltraScoot's Avatar
UltraScoot
ORIGINAL: Bigdaddy331
Thanks in adavance.
This is what you are looking for, will move your boards forward. very simple to fab this but take a look and you will get the idea.
CLICK HERE To see what I,m talking about.
Bruce
Old May 29, 2006 | 11:37 PM
Beemervet's Avatar
Beemervet
Am I reading it wrong? These are for Softails only.
Old May 30, 2006 | 02:51 AM
UltraScoot's Avatar
UltraScoot
ORIGINAL: Beemervet
same principle should apply to the touring, gives you idea what to fab or call these guys and they can prob. fab for you.
