I have 45K on my 09 RKC and no issues with the Jagg cooler. They are 100% behind there customer service at Jagg....Need to speak to someone just ask for Marvin...he owns the place....Good luck!
they fit and work well, this is them behind my Jagg 10 row low mount
Originally Posted by bikehe
Here found it but I dont know how good they are or whether one would fit behind a jagg 10 row without the tire getting too close. The fans are rated at IP54
TJ316, thanks for that buddy. I appreciate the fact that you went to the trouble of posting those pic's for me. I'm going to order both now I know they work together PS was there any problems getting both products to fit or was it pretty straight forward. Did you have to make any adjustments/modify anything?
they went right on without modifying anything, I have an oil temp guage on my bike so I went with the manuel model, if the temp went higher than I liked I'd flip the fans on and it would bring it down 3 - 4* and then maintain it there
This thread has piqued my interest in the cooler-fan concept again (for the third time) and I'm going to buy two of these myself. I already have a relay installed for the PCV switch, and it has another pair of connectors that output 12V I had earmarked for something like this. Flip the switch and the PCV runs a richer map and the fans come on.
As I mentioned yesterday, a couple of years ago I experimented on two separate occasions with fans, the first with two mounted outside the cooler, which was a failure since they contacted the fender when the forks compressed. Bummer. The second try was with two thinner fans mounted behind the cooler, but they began to fail after a few months exposed to water and other crud that got thrown up by the front tire.
That's him. I've had discussions with Milan for two or three years about his product and I've found him to be conscientious about improving these fan kits. The concept is good and the big problem he had for a while was locating reliable waterproof fans. I tried and although I found some descriptions I never located a source, but he did and has them available.
Iclick, been doing some more searching on the forum since posting and one guy had a problem trying to get the fans to fit on a 09 model FLHT. Not sure if it had something to do with the frame changes or whether the jagg cooler had a slightly different mounting point. He ended up modifying the jagg cooler and made an adapter to get the clearance he needed. TJ316 had no problems but not sure what year bike he has. Apparently Milan has only had 3 of his fan kits that gave any problems that I'm aware of. I emailed Milan and asked the question on the 09 model fitment and just waiting for a reply. I think your 07 should be ok and very interested in your findings if you wouldnt mind posting them please if you do go ahead and install some.
