Scary Handling
Old Sep 17, 2009 | 03:12 AM
  #31
triton5150's Avatar
triton5150
i realigned my 08 sg with a brick layers straight edge and it handled alot better. i tried E3s it was a little better than the dunlops. cycle gear had a sale so i switched to the metzlers and i will never buy another brand again. i would say it was a 40% improvement. no wandering or grabbing a groove. i always ran them on my crotch rockets but never thought to put them on any of my harleys.
Old Sep 17, 2009 | 04:57 AM
  #32
gabulldog's Avatar
gabulldog
When I first started riding my bike I bet I stopped 10 times thinking I had a "slack" rear tire because it felt like my tire was going flat. I found that even 1-2 lbs. of air pressure made a difference. Like someone else said I took off the stinking Dunlops and (In my case) put Avons on the bike, end of problem, I still check the pressure often, the following of grooves in the road totally stopped, it feels good in curves, much better on wet roads, etc. etc. Yes they are "Soft" and don't get the milage but I'd much rather be safe. I also went to 15 weight fork oil and "Works" rear shocks.
Old Sep 17, 2009 | 05:21 AM
  #33
!!!SPEEDY!!!'s Avatar
!!!SPEEDY!!!
Check out this product http://www.glide-pro.com/ this is soposed to cure most if not all the wiggleing, wobbleing.
Old Sep 17, 2009 | 06:14 AM
  #34
streetg7's Avatar
streetg7
thought it was just me...put a throttle-up stabilizer on my 07 SG...helps but as others have said..doesnt eliminate wobble. I am learning to live with it
Old Sep 17, 2009 | 06:35 AM
  #35
Notgrownup's Avatar
Notgrownup
Change your fork oil to Screaming Eagle heavy... it will stabilize your bike....When your front end is too soft you wobble going in a curve too fast...Tires make a big difference...The stock 402's don't handle that well...Metzelers handle better so do Avon's and Dunlop Elite 3's. I will definitely admit that a Goldwing handles much better than a Harley in the curves but do you really want to give up on HD....I am not ready for that....To each is own...I didn't install a brace, only the forkoil and the Hard riding i do in the NC mountains has really improved... Good luck.
Old Sep 17, 2009 | 07:53 AM
  #36
stevepacman's Avatar
stevepacman
Originally Posted by rochkes
You state that the problem is "lately".......... That means only one of two things. Either you are more comfortable on the bike now and are pushing it harder than you were before, or somthing has changed.
If you are riding more agressively now because you are more comfortable, then a stabalizer might be the answer.
If you are riding the same as you always have, and the problem is coming on 7,000 miles into it, something has changed with your bike. It could countless things.
Dennis
I agree with the "something has changed" theory. I once was an unbeliever. I've been beyond and back with this issue. I tried a chassis stabilizer (have removed it). I believe it is only masking a pre-existing problem. After new heavy fork oil, new tires and a Klock Werks windshield, she's solid as a rock.
Old Sep 17, 2009 | 08:20 AM
  #37
panheadache's Avatar
panheadache
my 07 doesn't exhibit it noticeably in turns, but i do not push the envelope much (geezer)...
however, this chassis design is reaching a damping/resonance issue at 80 mph and above, especially with excitation inputs such as rain grooves, a regular series of bumps or ruts, or the simple handlebar pulse input caused by rapidly reaching around with your hand and pulling your wallet out - ask me how i know about that one - it caused a WOOO Woo woo wo snake slither chassis shimmy that i thought was going to result in catastrophe like the handlebar/front end shimmy's of the old kaw h1's. definitely a puckering experience. recommend cooling it on these things - ride within the limits of the design... just my 2 cents...
Old Sep 17, 2009 | 09:41 AM
  #38
Bertk's Avatar
Bertk
Try the SE "Heavy" Fork Oil PN 99881-87. It's inexpensive and a do it your self job. I did it on my 08 SG and it was a big improvement. Here's a nice write-up on the process. Or you could go with a set of Progressive springs.
I recently installed the Progressive Drop-in Lowering Kit, drooped the front 1" with the SE "Heavy" fork out and was pleasantly surprised at how much nicer a ride they provide.
Old Sep 17, 2009 | 10:16 AM
  #39
gmc's Avatar
gmc
First I would start with rear tire change to Dunlop E3 even though there is some tread left it goes fast and it definetly effects handling when they get worn. I'm thinking since it just started this will help. Do you have spokes, or have lowered the bike, this can cause problems? If so make sure they are tight and true. Then fork oil, etc. as others have stated next. For some reason the whoble seem to be more prevalent with SG's and two of the main differences are the shorter shocks and the wheels.
Old Sep 17, 2009 | 10:35 AM
  #40
Bertk's Avatar
Bertk
The OP never mentioned a wobble!
