Road king Popping when shifting and decel
Old Jun 4, 2006 | 09:29 PM
gasman's Avatar
gasman
Default Road king Popping when shifting and decel
My new ,used 03 Screaming Eagle Road King makes a load pop out the exhaust when shifting from 1st to second at 2-2500 rpm's and 2nd to third at about the same rpm's. I have the Rinehart true duel, PC111 and Big sucker Air cleaner.
Eastern Performance installed everything and dynoed it for the previous owner. IS this normal or do I have a mapping problem or something else.
It also feels like it missing real bad excelerating in 1st gear and reving the engine with the clutch disengaged. I know it's EFI but it feels like the idle/air mixture screws need adjusting (which I know it doesn't have).
Are these things normal for an A engine especially with the 103ci engine?
Thanks Gasman
Old Jun 4, 2006 | 11:06 PM
MACK's Avatar
MACK
Default RE: Road king Popping when shifting and decel
YOU HAVE MAPPING PROBLEMS AND SOUNDS LIKE YOU ARE ON THE LEAN SIDE. THE RACE TUNER WILL FIX IT.
Old Jun 5, 2006 | 01:00 AM
bountyhunter's Avatar
bountyhunter
Get the bike to a reputable dyno shop!
Old Jun 5, 2006 | 01:35 AM
SteveO's Avatar
SteveO
I had the same problem. Got the Power Commander wiring harness wet while washing, backfired and popped and finally fouled a spark plug. Check the wiring harness, and change the plugs. Shifting around 2000 RPM is lugging the engine, not good!
Steve
Old Jun 5, 2006 | 01:39 AM
mikeisglidn's Avatar
mikeisglidn
can the injection!!!
Old Jun 5, 2006 | 11:03 PM
rdking330's Avatar
rdking330
Running lean will do it, try re-mapping, go to the Power Commader web site to check out some maps...or call them
Old Jun 6, 2006 | 01:08 AM
turbo54's Avatar
turbo54
My 2000 95 RG do's that same thing Im taking it in for a second time . I think it's intake leak along with the stage 2 down load. It trashed 2 pc3 Im going to try a different wrench this week . Itake leak will mess the fuel ration up .
[IMG]local://upfiles/3159/5BEDB7C895534C37A115DB7B6C61F167.jpg[/IMG]
Old Jun 7, 2006 | 12:27 AM
gasman's Avatar
gasman
I checked my exhaust flange nuts tonight and guess what? 2 were missing and the other 2 were just barley on. I ran to home depot and found some 5/16 fine thread nut and put a washer behind it and tighted them as snug as I could get them. I wonder if this could have been some of my missing, popping problems? Will this mean I will have to replace the gaskets? I will ride it tommorrow to see how it performs.
Old Jun 7, 2006 | 12:30 AM
Bryan TTM's Avatar
Bryan TTM
it could be the poppin
Old Jun 7, 2006 | 02:52 AM
firestar99's Avatar
firestar99
MIKEISGLIDEN ***HATE to tell you but from 07 on there will only be fuel injecton. they are doing away with the carb models.
Charlie51
Aug 28, 2016 12:59 PM
jimdp
Apr 3, 2013 08:30 PM
250REDNECK
Exhaust System Topics
Jun 25, 2011 10:08 PM
pt3435
Sep 29, 2007 06:58 AM
rossmanshff
Sep 28, 2006 12:25 AM
