Motorcycle lifts
Old Aug 23, 2009 | 06:24 AM
danielcullnan's Avatar
danielcullnan
3rd Gear
Default Motorcycle lifts
Has anybody used the Motorcycle lift from JS Jacks ? Looks pretty good I am interested in finding a bike lift for my 2007 Harley Davidson Electra Glide Classic Thank you for any info anybody has Have a great ride
http://www.jsjacks.com/index.htm
Old Aug 23, 2009 | 06:37 AM
n8dc's Avatar
n8dc
do a search there are countless posts on jacks.. I have the sears red one and it works great for me.. By the way what oil are you using ?
Old Aug 23, 2009 | 06:46 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by danielcullnan
...Thank you for any info anybody has...
I have no experience with this one.
But stay away from the Larin line of jacks. I've had them replace the bottle on the jack three times...two within the first or second use.
Nothing more frustrating then raising the bike only to find the bottle jack will stick in the up position. Try lifting a 900 lb bike off a jack
Old Aug 23, 2009 | 06:47 AM
rfultra's Avatar
rfultra
i also use the red sears jack. works great on my Ultra Classic. Good luck
Old Aug 23, 2009 | 07:03 AM
lowflyer's Avatar
lowflyer
J&S works good for me. It`s built wider which gives it stability. The other jacks look small after you get one. I can use it to change tires on my Benz too (had to give it an initiation).
Old Aug 23, 2009 | 07:17 AM
danielcullnan
3rd Gear
Jeez I can not believe all the responses Thank you all Dave The oil I use is Amsoil
Also Pine Tree how the @#!$# did you get the bike off that Jack ? I got to know
Old Aug 23, 2009 | 07:26 AM
BOBSFLHX's Avatar
BOBSFLHX
J&S All the Way Use it on my 2008 SG Easy on Easy Off Super Stable I also have the Craftsmen Jack just for the Wifes 04 883XLC. J&S Great Jack Craftsmen Good Jack.
Old Aug 23, 2009 | 07:39 AM
les63's Avatar
les63
J&S all the way, I put the King on it and push it all around the garage with no tie downs, works great. I also have the sears aluminum yellow jack and it works good also.
Just depends on how muich you are willing to spend.
Old Aug 23, 2009 | 07:46 AM
deltasnook's Avatar
deltasnook
I have a HF yellow and it works fine on my RK.
Old Aug 23, 2009 | 07:52 AM
IndyClassic's Avatar
IndyClassic
Had the red Sears for years, works great. Left it for my son-in-law when I moved and had the JS waiting on me here when I arrived. I am very happy with the JS....much easier to move around once bike is up and a bit steadier then ol'red IMO.
If the $'s are tight I would not hesitate on the Sears red, but I do like the JS better. n8dc is dead-on......you can find countless threads in here on the "debate."
