Bald Tire - Puzzled
Old Aug 23, 2009 | 06:33 PM
usmcdevildog's Avatar
usmcdevildog
Default Bald Tire - Puzzled
I have a 2001 EGC with just about 10,000 miles on the bike, and the tires are original. A month ago the tires looked hardly worn at all. I noticed yesterday that the rear tire is now bald. All the way around the tire it is flat and there is no tread about 2-3 inches wide. The edges of the tire still look hardly worn. The front tire also looks hardly worn too.
I don't do burnouts or lock up the tires. The tire pressure is at the proper level.
First I would like to know if this is normal. Is there a reason why only the rear tire would be bald?
Why did it seem to wear so fast? I did put 3000 miles on the bike in the last month.
Also, could I replace only the rear, or should I replace both at the same time?
Old Aug 23, 2009 | 06:50 PM
ord sgt's Avatar
ord sgt
Old tires, old rubber. No flex in the tread, so faster wear. Were you carring more total weight on the motorcycle than earlier?
10,000 miles is a little early for that much wear, but I have read of others that have worn the tires with fewer miles.
If the front tire is still good tread, no problem just doing the rear tire. I have replaced my back tire after 14,000 and still have fair tread on the front.
Old Aug 23, 2009 | 06:54 PM
1plumr1's Avatar
1plumr1
rear to front wear will be 2-1 or 3-1 depending on your acceleration practices. 10-12k is pretty normal on a stock touring rear. I normally get 12-13k on my ultra, but I drive like an old lady (except for the twisties). My current rear turned 14k today and still has 1-2k left. it has all been long distance hiway miles. 28k on the front (stock dunlops).
Old Aug 23, 2009 | 06:57 PM
vindex1963's Avatar
vindex1963
Some people are heavy on their rear brake and it's the least effective in stopping.
bigdumbnoitall00's Avatar
bigdumbnoitall00
thats normal 10-12 on the rear 18-22 front however with the age of that front id change it out as well.
Old Aug 23, 2009 | 07:01 PM
will2002's Avatar
will2002
I only get 6K on a rear tire. I do get 20K on a front though-------- I would KILL to get 10K on my '02 rear tire!
Old Aug 23, 2009 | 07:03 PM
skootchnc's Avatar
skootchnc
Originally Posted by ord sgt
Old tires, old rubber. No flex in the tread, so faster wear. .
we have a winner..... 8 year old tires, that suddenly start getting used, aren't going to last.
Get yourself a set of new tires, and don't worry about it
Old Aug 23, 2009 | 07:33 PM
robbie52's Avatar
robbie52
Tires are old and probably starting to dry rot. Get two new tires, not worth the risk.
Old Aug 23, 2009 | 07:38 PM
gver1031's Avatar
gver1031
replace your tires with elite3's a better dunlop tire that will increase your milage the are a little harder compound but ride good you should be able to get average of 18000 on them if you keep them inflated to 40psi
Old Aug 23, 2009 | 07:47 PM
dabluesguy's Avatar
dabluesguy
Because of the age of the tires you really should replace both. Read some of the threads about the Dunlop Elite 3 tires. People seem to think they are the hot setup.
