Oil Level Problem or Not??
Old Aug 25, 2009 | 10:53 AM
nfe's Avatar
nfe
Turkey baster works great for me if it reaches. If that doesn't work, then just remove the filter, and drain and replace is another way to handle this issue... Then top off if you are low after re-pressurizing...
Old Aug 25, 2009 | 11:07 AM
ncbeast's Avatar
ncbeast
Yeah, rather not go through the whole filter than again, that was a pain. Used the 2 litler bottle method and the aluminum foil and still made a mess. I am hoping a turkey baster will work or I will have to rig something up.
Old Aug 25, 2009 | 11:14 AM
DMcBiker's Avatar
DMcBiker
Why not just remove the bottom drain plug and just drain a bit off. Way less mess then removing the oil filter.
Old Aug 25, 2009 | 11:22 AM
mainshaft's Avatar
mainshaft
+1 with DMcBiker, if I had to drain some out, I would go to the plug and drain there. I keep mine half way between full and add when the oil is cold.
Old Aug 25, 2009 | 11:32 AM
Firebike32's Avatar
Firebike32
[quote=ncbeast;5485234]Crap, I just changed my oil for the first time (5000) on my 2008 RG and I filled to the top fill line. It was just a little over 3 1/2 quarts. I rode it down the street afterwards but not very far and then put her back up. So I guess I over filled it but may not got it hot enough to blow out of the air cleaner.
What will be the best way to remove some oil to get the cold level down?
Greg-I've used a small plastic tube and just syphoned some out.
Old Aug 25, 2009 | 11:49 AM
TheJimer's Avatar
TheJimer
A turkey baster is the easy way to go!
Old Aug 28, 2009 | 06:43 AM
ncbeast's Avatar
ncbeast
Turkey baster worked great. Pulled out about 4 baster fulls which brought the cold level down to the half way mark.
Thanks for the help!
Old Sep 5, 2009 | 08:02 AM
Pfrancish's Avatar
Pfrancish
My brother had a oil change done at the dealer and they overfilled his 09 Ultra. As a result he had oil coming out his air filter. How long can he expected to see the oil seeping from his air filter?
SH_01FXDWG
Jun 13, 2015 05:13 PM
MURPHCC1
Oil Archive (no new posts)
Mar 11, 2014 09:13 PM
EdandGrace
Aug 5, 2013 08:32 PM
streeteagle
Sep 25, 2011 08:26 AM
sparky_mo
Aug 27, 2008 09:40 AM
