Got's 2 know
Old Aug 25, 2009 | 05:37 AM
smokindave's Avatar
smokindave
The stock exhaust header is really a 2-1 system and yes a 2-1 pipe will perform better. The crossover pipe is for reverberation only. This is so the exhaust sounds the same out of both pipes, while the right pipe has most of the exhaust gases. You can feel the left pipe is cooler than the right and on a cool morning will even see more condensation coming out of the right than the left. It is important for performance that when you consider slip on mufflers you should ask about the baffles installed. On Fuelmoto mufflers Jamie puts a larger baffle on the right and smaller on the left for a reason.
Old Aug 25, 2009 | 05:44 AM
KopperTop's Avatar
KopperTop
Yeah, the the stock is exhaust is essentially a 2:1 with the left can being mostly for show. When I put V&H ovals on my stock headers, I noticed the inner oval tips were aging (discoloring) differently because of the heat/exhaust difference between the two sides. I finally settled on True Duals with V&H Classics and the bike/engine and my legs are much happier.
Old Aug 25, 2009 | 06:24 AM
Motorboatn SOB's Avatar
Motorboatn SOB
HD is not worried about getting performance out of the stock bike! If they were a 96" engine would be coming stock with 100HP / 100 Tq stock like it should. Instead they know we'll spend a fortune building / tunning it up to where it should have been in the first place. This subject gets me fired up.
OldPhat
Mar 13, 2014 09:37 PM
schumacher
Nov 3, 2009 09:35 AM
dark_glide
Sep 28, 2009 10:01 AM
bmelby
Exhaust System Topics
Apr 5, 2009 10:05 AM
BIG THUNDER
Jun 25, 2006 03:11 AM
