Help please-no start after changing ignition module
Old Aug 30, 2009 | 05:39 PM
Eric in chicago's Avatar
Eric in chicago
Default Help please-no start after changing ignition module
What a long weekend. 700.00 from the dealer seems like a deal on putting new bars on the bike this weekend. Got everything back together but managed to crack the ignition switch. Got a new one and everything works but the bike will crank but not fire. I screwed around to get the ignition switch to line up without the special ignition alignment tool but it wont turn over. I thought low voltage, it is only cranking at 10V. Got it on the battery tender to juice up but It was on the tender all night. 5 mins of cranking (off and on over 1/2 hour should not drain that much...) all fuses are good, got the headlight fuse to save cranking power drain. I am stuck. Thought it might be a wire in the new wire extensions but it is trying to crank, just wont catch. Any ideas??
Old Aug 30, 2009 | 10:40 PM
stro1965's Avatar
stro1965
Can you hear the fuel pump priming?
Old Aug 31, 2009 | 09:00 AM
lowflyer's Avatar
lowflyer
check the kill switch on right handlebar, if you messed with wiring it`s a likely culprit
Old Aug 31, 2009 | 10:38 AM
Eric in chicago
Thanks for the replies, I threw in the towel and called the dealer to pick up the bike. I'll bet it is a pinched wire but did not have the energy to pull everything off and start the wire project over. Will post back what the findings are
EVOrider
EVO
26
Jul 20, 2019 04:45 PM
rgsand
EVO
Mar 5, 2018 04:35 PM
neverdown
May 5, 2013 07:08 PM
FLYSBY
Electrical/Lighting/Alarm
Mar 3, 2013 03:37 PM
maxxod
Mar 9, 2012 06:10 PM
