Replacing '09 California Header Question
Old Sep 1, 2009 | 10:35 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Originally Posted by marcparnes
The '09 California model has the cat in the head pipe while the other 49 state bikes have the cat further down stream. As I understand it all the '10 bikes now have the cat in the headpipe. What Jamie confirmed is exactly what I was assuming, that removing the cat should reduce the amount of heat to the legs on the r/s. In that case it makes it worthwhile to do. On the other hand r8rs4lf drilled his out and didn't notice a reduction in heat. I would imagine if you didn't have lowers you might not notice any change. Unless I get stuck in traffic I really don't notice any great amount of heat without lowers. With lowers it's pretty hot once the air temp gets over about 80F or so. I think it might be worthwhile to swap the headpipe and see how it is. I can always put the cat pipe back if CA actually follows through on their threat to start smog checking bikes.
Marc
Did "r8rs4lf" actually measure the heat with a sensor? Or did he use the "butt" sensor that some people dyno with?
Old Sep 1, 2009 | 10:44 PM
marcparnes's Avatar
marcparnes
Yes, I assumed that if you remove the headpipe, which has the cat in it, you're out of compliance. California has been threatening for years to start smog checking bikes but it hasn't happened as of yet. I've done the same thing with my BMW. It also has the cat in the headpipe which I've replaced with a Remus system. The one good thing is that it's no big deal to put it back to stock if the need arises. And no harm done. I'd really like to reduce the amount of radiated heat with lowers on and maybe changing out the headpipe might help.
Marc
Originally Posted by sonar_chris
I understand that, what I was trying to say is that one of the ramifications of replacing it with a non CAT head pipe is you will no longer be CARB or EPA compliment for emissions or smog if you prefer. You can however change the mufflers and still remain EPA/CARB emissions compliant. I have PDF flies from CARB proving that most Vance & Hines mufflers are still compliant as long as you use the stock head pipe.
Old Sep 2, 2009 | 07:01 AM
r8rs4lf's Avatar
r8rs4lf
No sensor here because it's really not that serious to me. I mostly did it to get the ovals to bark a little which, by my ear, it did. Maybe not all that much, but I can't go back and change it anyways. One would think the headpipe "would" be cooler without the catalyst in there.
Old Sep 2, 2009 | 07:22 AM
IAMSWUTIAMS
Nice bike!
Old Sep 2, 2009 | 10:08 AM
bubbleb's Avatar
bubbleb
my father in law and a buddy of his put the RUSH true duals on their FLs because they advertised heat reduction of around 300 degrees. both of them said they noticed a huge difference. so when i decided to put a full system on my street bob, i called rush and they informed me that they ceramic coat the inside and outside of all their head pipes. as soon as their dyna systems are out ill be putting a set on my bike along with a tuner and air cleaner. just my 2 cents.
Lightngsvt
Milwaukee Eight (M8)
36
Jul 2, 2019 12:17 PM
dviljoen
Exhaust System Topics
Mar 31, 2018 12:12 PM
bald1der
Dec 24, 2010 08:42 AM
datsbad
Mar 29, 2010 05:42 AM
marcparnes
Nov 5, 2009 01:30 AM
