The ABS and rear brake will disconnect and the pedal will go to the floor if you were downshifting and using engine braking while coming to a stop. This is a NORMAL ABS response!
There are warnings against doing this in the manual. You might want to recheck this section and make sure you are riding the bike properly.
Maybe we got different manuals with our bikes? Never heard this one before.
This is news to me, I've never read that any where.
Sure would like to know how this worked out. After reading through seven pages, it was like the cable TV going out 15 minutes before the end of the movie . . . Did anyone give the OP a solid explanation or did they just return the bike "fixed" and mumble something about "we put all new ABS parts in and went over everything and it's good to go"?
I cannot see how this is possible??? From a control perspective there is no interaction between the 2 systems whatsoever, and why would anyone want to implement such a system.
Now, if you are saying that changing down shifts the bike CG forward, reduces load on the back wheel which results in a similar braking force initiating ABS then I think you would be in the right track, but that is more "cause and effect" than part of a control system
A warped brake rotor will cause the same thing. You can pump the brakes up, but when the bike is rolled the warped rotor will push the brake pistons back into the caliper,which will cause the loss of brakes until they are pumped again. But I am sure it is easier to blame it on the abs.By the way the front and rear brakes share the same pump.
Havent forgot you guys......bikes still in the shop and my frustration level is getting very high. I am scheduled to meet with the Service Tech and Service Manager when they call me to pick it up for a full explanation of what happened.
That explanation makes more sense than anything else so far. I bet you nailed it.
