What accessories do you need while riding?
If you are not riding then you will not need the accessory switch on.
Just add a 12 volt power outlet in the trunk or saddle bag. Cheap insurance.
I can see the rear accessory lighting but what else.
Turn off the accessory switch when charging the phone, problem solved.
the accessory switch is just used for my heated vest. cig lighter for phone charging. i only have the switch on when i'm needing the vest but ya, i'll prol try and avoid charging the phone and being warm at the same time
I had a problem with my cig lighter burning out my fuse all the time. after looking into it some it turned out the lighter itself had alot of rust build up inside I switched it out with a new one and now its fine
