Engine Idles fast when hot
Old Oct 1, 2009 | 10:00 PM
1sweetglide08's Avatar
1sweetglide08
Default Engine Idles fast when hot
Does anyone have a problem with their bike idling too fast when hot? I have a 08 Street Glide and when my bike gets hot it idles up and down when stopping. Then when turned off for a while it returns to normal. Does anyone know what can be causing this?
Old Oct 1, 2009 | 10:56 PM
SlowGlide2989's Avatar
SlowGlide2989
Its normal, when they get hot there is a preset temperture that the idle goes up a 100 or so rpms to help circulation to cool things down. See if you have the option to roll the throttle forward to cut the rear cylinder out when at lights.
Old Oct 13, 2009 | 01:50 PM
BFMC27's Avatar
BFMC27
1st Gear
what slow glide is talking about is parade mode. you can manualy adj your air to fuel mixture to a a richer mixture that is preset when in stop and go traffic and dont have a lot of air to cool your engine ie parades. holding the throttle forward for 3 seconds. you will see the cruise light flash green. this means its on. repeat and it flashes red/off
for what you are describing try this pay attention to where your throttle position/rpm's are when you turn the bike off. the ecm uses where ever it is when it shuts down as "zero" but limits to 2000.
to reset
turn the run/stop on the handlebar to run
turn the ignition on the tank to on
allow check engine light to go out
turn ignition on tank off
repeat 5x's
this will reset your throttle position sensor for fly by wire
Old Oct 13, 2009 | 03:34 PM
gunner11's Avatar
gunner11
You should have that option, I have an 08 Ultra and it's on mine, g9ive it a try and you'll see it. Green on, orange or red off.
Hogdoc45
15
Nov 15, 2018 07:21 AM
DanHappy
Jul 15, 2015 05:59 AM
cjairplane
Aug 20, 2010 12:36 PM
rwj4709
Aug 11, 2008 06:27 PM
