clutch cable repacement
Old Oct 9, 2009 | 06:28 PM
kingdavid's Avatar
kingdavid
Stage II
Default clutch cable repacement
Replacing the stock cables on my 09 RK with braided and looking to avoid the $60 shop manual. Does anyone have the procedure for removing/replacing the cable and adjusting the clutch?
Old Oct 9, 2009 | 07:22 PM
tencrore's Avatar
tencrore
My advice, along with probably most others on this forum, would be to invest in the shop manual. You bought a bike close to $20K, I don't think it wise to NOT invest $60.00 in a shop manual. If you are anything like the rest of us, you probably will not stop at just the braided cables, you'll be wanting to do much more to your bike yourself. The shop manual will be your best resource.
Old Oct 9, 2009 | 08:59 PM
gunnert's Avatar
gunnert
I'm with Tencorce, you really do need the Service Manual. And while you're at it spend another $40 bucks and the Parts Manual for your bike. I find myself using Parts Manuals more than service manuals.
Old Oct 9, 2009 | 09:05 PM
Duracell's Avatar
Duracell
If your cheap enough to want to do it yourself ( and you should be ) That $60 manual will save you more money than you can imagine. Best money you can spend.
Old Oct 9, 2009 | 09:09 PM
mastery's Avatar
mastery
Like everybody else said, spend the money on the manual. You can sometimes find it cheaper online. Plus, you'll find that with the manual, you will end up doing more stuff yourself, and save much more than the $60 or whatever the manual will cost you. I know I've saved at least $500 from buying my manual and doing things myself.
Old Oct 9, 2009 | 09:17 PM
Taterdog's Avatar
Taterdog
Have you bought the manual yet? What are you waiting for?
Clutch cable replacement is an easy job as long as you have the right cable, and cable adjustment is even easier. But, get the manual -- best $60 you'll spend on the bike.
Old Oct 9, 2009 | 09:24 PM
Notgrownup's Avatar
Notgrownup
First disconnect the battery, then loosen the cable then go buy a manual. then follow the other instructions.
Old Oct 9, 2009 | 09:52 PM
kingdavid's Avatar
kingdavid
Stage II
okay, okay! I'm buying the manual.
Thanks to all for what I am sure is good advice.
Old Oct 9, 2009 | 09:58 PM
Taterdog's Avatar
Taterdog
Good, there will be a test on Monday!
JuniorNasty
Apr 24, 2014 02:10 PM
LJROY
Jan 11, 2012 08:24 AM
Ironhead Jamie
Ironhead
Aug 22, 2009 07:37 PM
scottharstad
May 14, 2009 12:10 AM
bakerm75
Feb 25, 2009 10:05 PM
