Speedometer wiring
Old Oct 23, 2009 | 06:19 PM
shewey's Avatar
shewey
Stage III
Default Speedometer wiring
Would anyone have a wiring schematic of the 12 pins on the back of a speedo part#67517-08.Any help would be great. Thanks.
Old Apr 19, 2012 | 11:44 AM
Winners08Rocker's Avatar
Winners08Rocker
Back from the dead... yes. But in case anyone else needs this.
Old Mar 30, 2024 | 05:51 AM
Nogoodstreetglide's Avatar
Nogoodstreetglide
1st Gear
New to the site and I just seen this. Would you happen to have the speedometer wiring for a 17 street glide special that uses all 12 pins?
[/QUOTE]
Old Mar 30, 2024 | 06:56 AM
Vernal's Avatar
Vernal
@Nogoodstreetglide Welcome to the Forum from Utah. Doesn't look like the instrument module uses all 12 pins.
Old Mar 30, 2024 | 07:36 AM
Nogoodstreetglide
1st Gear
Is that for the 2017 flhxs? Yeah it uses all 12. I have not been able to find one at all. I've looked everywhere even called the dealership they wouldn't give it to me, but I don't think that is it.
Old Mar 30, 2024 | 07:38 AM
Nogoodstreetglide
1st Gear
I was pretty sure it did anyways, but I'll try on this diagram just to be on the safe side but I was thought it did all 12. I'll let you know.
Old Mar 30, 2024 | 07:56 AM
Vernal's Avatar
Vernal
@Nogoodstreetglide The Non fairing bikes use all 12, at least that's what the Manual shows.
Old Mar 30, 2024 | 09:08 AM
Nogoodstreetglide
1st Gear
Maybe I'm not remembering correctly. I'll figure it out but thank you so much for those wiring diagrams.
Old Mar 30, 2024 | 10:25 AM
GalvTexGuy's Avatar
GalvTexGuy
I looked at every wiring schematic for touring with fairing and I’ll be damned if I could find the wiring diagram for the speedometer. Like you, I found non-fairing, but not with fairing.
Old Mar 30, 2024 | 01:00 PM
Vernal's Avatar
Vernal
@GalvTexGuy
It's confusing.
Once they put a fairing on, the "speedometer" becomes the Instrument Module. The connector number 39 is common to both, but the fairing models must use the HD Link output from the IM to control turn signal indicators .
