Speaker wiring question??
Old Oct 24, 2009 | 04:24 PM
billjoat's Avatar
billjoat
Default Speaker wiring question??
When you install a radio on a harley, and have 2 speakers to be mounted to the handlebar area, how do you wire the speakers, preferably? Do you only use the front speaker wires off the radio, the fronts to one and rears to the other, the lefts to one and the rights to the other, or just the rears?
Old Oct 24, 2009 | 04:36 PM
Glenn W's Avatar
Glenn W
If they are the std color codes you'll have a pair of green, purple, white, & gray wires. One of each would be the negative and it'll have a black stripe.
Usually folks just use the front sets (white-left & gray-right) and tape off the other ones. Unless the instructions say the amps can be bridged and shows you how, do NOT put the front & rear pairs on the same speaker, it'll kill the radio.
Old Oct 24, 2009 | 04:39 PM
billjoat's Avatar
billjoat
Using just the fronts made the most sense. Thanks for the quick reply.
Old Oct 24, 2009 | 11:15 PM
Glenn W's Avatar
Glenn W
You're welcome. I forgot to mention, there's no difference/advantage on most radios in using the front sets over the rears, but in general practice it usually best to use the fronts. This is because on head units with internally bridgeable amplifier chipsets you can select between 2 or 4 speaker use. If you select 2 speaker mode on those it'll be the front set that's enabled so it's just a good habit to use the front sets regardless.
badge502
Audio Systems
Sep 18, 2017 06:11 PM
blackv03
Audio Systems
11
Mar 21, 2016 02:59 PM
Griff123
Mar 25, 2014 05:13 PM
jgcable
May 5, 2010 09:20 AM
Bad Pig
Aug 31, 2008 01:40 PM
