?? SE Compensator ??
Old Oct 28, 2009 | 05:56 AM
UltraDave's Avatar
UltraDave
Originally Posted by oinker02
No, but it will eliminate noises that the IDS does not fix.......The IDS only reduces the noises made by the OEM comp
So, it would seem that if you had both IDS and the SE comp, the bike would run really smooth?
I know the IDS on my scoot made a world of difference in the ride. I've been thinking about the comp as I get a fair amount of knocking up front in the primary area and do have that slack in the primary chain that dirtdobber wrote about.
Old Oct 28, 2009 | 06:31 AM
racerdave's Avatar
racerdave
Oinkers post explains a lot. But what do some of you guys mean by "bottoming out" ??
Old Oct 28, 2009 | 06:39 AM
chasswartz's Avatar
chasswartz
Default Good explanation
Wrong, it does help higher compression engines start smoother and quicker. ESPECIALLY higher compression engines!
On startup, the starter instantly engages and applies huge torque to the rear primary sprocket. That turning force is then transmitted to the front sprocket via the primary chain. At that instant, the top of the chain is being pushed forward by the rear sprocket, not pulled forward by the front sprocket, so all slack in the chain at the bottom is then transferred to the top of the chain. When that happens the chain tensioner gets compressed and a HUGE turning shock is then transmitted to the front sprocket. That huge shock will instantly overcome the light spring in the OEM comp(that's when you hear the loud knock) and the crank will begin to turn and spark fire......Then due to the too weak spring, the chain will then slacken, then tighten again generating yet another but not as forceful turning shock as the first and during the slack time the engine will try to roll backwards due to compression........All in all, what happens is due to the weak spring and ramp design in the OEM comp, the crank does not receive a smooth flutterless twist from the starter. It instead gets slacked, , jerked, rolls backwards, and then jerked hard again several times. The SE comp has a much heavier spring and will absorb much more shock without bottoming out and it also greatly reduce the slack because it doesn't bottom out.
Imagine you are trying to start a pull start lawn mower where the rope isn't wound properly and has a few slack places in it on the crank pully, and when you pull the rope, it first jerks up the slack, then turns the engine a little, then has another few inches of slack, then turns the engine a little more, then a little more slack till then engine finally starts.
It's the same thing.
This is the best explanation I have seen in all my searching.
Old Oct 28, 2009 | 06:45 AM
Scorpion07's Avatar
Scorpion07
From all the reading I've done on both these parts, I'm leaning that way. I know for fact that the IDS dampened a ton of driveline lash on my 07. Probably my best mod so far. So much more refined. AND - like any mod - if that was good, more is better!
I do still question weather or not they work well together. Especially since they are designed for totally different purposes.
That being said, the SE Comp is still on my wish list....
Old Oct 28, 2009 | 06:47 AM
chasswartz's Avatar
chasswartz
The starter compresses the spring pack to the point it becomes a solid connection. The problem is it is solid in one direction only, as soon as you pass the compression stroke the bottoming out goes away, this is what causes the 'jerky' load to the starter.
Old Oct 28, 2009 | 06:52 AM
Scorpion07's Avatar
Scorpion07
The stock compensator turns on a ramped cam that is limited by the pulley housing (otherwise it would just roll over onto another ramp). When the cam hits this limit - it "bottoms out".
Old Oct 28, 2009 | 07:03 AM
chasswartz's Avatar
chasswartz
I don't see any reason they would not work together. I don't have a IDS on my 07 and have never had any of the drive line issues I have read about here. The main reason I put the SE comp. in was to get rid of the start up clunk. I also will be installing a 103 kit soon, and the new comp should handle the extra power. I did not have any issues with the stock comp other than the start-up clunk. I have not seen any differance with the new comp other than a smoother start-up an possibly a smoother hot idle. The smoother idle may be also due to the cooler weather, I have not been able to get oil temp over 190 f. It may also be due to the heaver fly wheel effect of the SE Comp.
Old Oct 28, 2009 | 07:09 AM
smokindave's Avatar
smokindave
Look at the two pics below and notice the new SE compensator has clutches in it and the old one (you have) does not. The torque from the crankshaft makes the old compensator take off up the ramp bottoming on the ramp when you hit the starter. The clutches on the new compensator takes this load thereby eliminating the fast ramp up on the old compensator.
Attached Thumbnails ?? SE Compensator ??-old-20comp.jpg   ?? SE Compensator ??-new-20comp.jpg
Old Oct 28, 2009 | 07:21 AM
chasswartz's Avatar
chasswartz
Default springs not clutches
Those are springs not clutches. The stock comp also has springs in the roter housing extension, just much lighter springs. The SE has 3 sets of springs {wave washer type] each one progressively stronger. I have not taken the springs out of the old comp for inspection, but they look much weaker than the SE comp.
Old Oct 28, 2009 | 07:51 AM
smokindave's Avatar
smokindave
Yes, you are correct in calling them springs. When the springs take on pressure they collapse somewhat and take pressure from the torque off the crank. The problem is like you have said, they are weak. This allows the compensator to ramp up and bottom out.
I have added pics of my stock compensator. Notice the TWO springs inside, one thicker than the other. These are what take the initial load off the crank and are not heavt enough. I also added the parts page for the new compensator which clearly shows the difference in the two.
Bottom line, it's better.
Attached Thumbnails ?? SE Compensator ??-img_2203.jpg   ?? SE Compensator ??-new-20comp-2.jpg
