It did it again, WTF????
Old Jul 7, 2006 | 11:40 AM
04RoadKing's Avatar
04RoadKing
Default It did it again, WTF????
Ok, WTF is going on? For some reason my mini tach and my speedo stoped working. It did for the first time last week on my way home from work. When I got home I checked the fuses and they were all ok. I removed the fuse for gage's and put it back in and everything worked just fine. But then it happend again on my way to work today. As soon as I relized that they were not working I pulled over and shut off the engine and restarted it and everything was working just fine.... WTF is going on??? Has anyone ever had this problem? I'm going to ride to Sturgis this year and just don't want any problems on my trip. Thanks for any input.
Old Jul 7, 2006 | 01:48 PM
bluesgub's Avatar
bluesgub
Default RE: It did it again, WTF????
I've had that problem when I shut the motor off and don't use the kill switch. I'll be keeping up with freeway traffic and the speedometer says I'm going 20mph. Stays that way till I override it by using the kill switch.
Old Jul 7, 2006 | 04:30 PM
04RoadKing's Avatar
04RoadKing
ORIGINAL: bluesgub
So maybe I should start using the kill switch and see if it does it still. Thanks for the input.
Old Jul 7, 2006 | 04:34 PM
sleepneagle's Avatar
sleepneagle
Right about kill switch. There has been a problem with some models concerning speedo and speedo/tach registering properly. Come to find out, it had to do with how the engine is shut off. Shut off sequence should be, kill switch, turn ignition off. On start, kill switch on, turn ignition on.
Old Jul 7, 2006 | 04:57 PM
04RoadKing's Avatar
04RoadKing
Thanks sleepneagle I will try to remember to start doing it that way. Old habits are hard to break.
dme109
2014-2024 Touring Models
Jun 25, 2015 09:02 PM
DeeRides
Apr 1, 2013 02:39 AM
JustDave71
Jun 3, 2012 11:08 AM
apknight
Mar 23, 2010 11:04 PM
jonhoffers
Aug 9, 2006 05:50 PM
