flhrci running hot?
Old Jul 8, 2006 | 07:06 PM
cbwat1's Avatar
cbwat1
Default flhrci running hot?
I just traded my 04 sporty for an 03 FLHRCI. I know the Road King is alot bigger but it seems like it's putting off alot of heat while and after riding. Am I just use to the smaller 1200 or could there be a problem? I just went for a short ride and I could feel the heat through my jeans. The bike has 10,500 miles on it.
Old Jul 9, 2006 | 09:00 AM
Longtimegone's Avatar
Longtimegone
Default RE: flhrci running hot?
I doubt if there is a problem. On a good hot day you can just feel the heat more. Most of the heat is coming from the stock exhaust crossover. If the bike has the original factory tuning for A/F mix, then it is running very lean and much hotter than it would with a richer mix. The concensus around here is to go with a good aftermarket exhaust and air cleaner then add the Screaming Eagle Race Tuner or Power Commander III with a good tune on a dynomometer. The tuner can richen up the lean A/F. You get more torque and hp, plus the engine will not heat as much. You're call ....
Ride Safe.
BigJohn75
Feb 13, 2017 12:20 AM
BBSHK
Apr 12, 2014 04:25 AM
prider
20
Oct 9, 2012 02:13 AM
trane0605
Jul 9, 2008 03:56 PM
AceHog
Jun 14, 2006 10:32 AM
