Unknown knocking problem solved!
Old Nov 21, 2009 | 10:02 AM
Cheiron's Avatar
Cheiron
davessworks,
The weight of the bike rests on the bottom bearing keeping it tight. The grease is going to take the path of least resistance to get out, the top. The steering head may need to be snugged up a bit to equalize the pressure on the two bearing cups (to spec).
Cheiron
Old Nov 21, 2009 | 10:06 AM
Faast Ed's Avatar
Faast Ed
Originally Posted by davessworks
Funny I was just doing this on my '01 bike. I have all the grease coming out the top and none out the bottom - ideas?
I'd leave it. Gravity will take care of the rest. (What Cheiron said too - make sure they are tight).
Old Nov 21, 2009 | 01:26 PM
davessworks's Avatar
davessworks
Originally Posted by Cheiron
davessworks,
Cheiron
Yeah - I'm checking the steering head adjustment although the whole fall away adjustment approach doesn't seem to work so well on my bike due to wiring and throttle cables. Regarding the bike sitting on the lower bearing - good point - although I had the bike on a lift at the time.
Old Nov 21, 2009 | 03:25 PM
rsavage's Avatar
rsavage
You can temporarily tie a piece of heavy string/light cord around the bearing head where the grease is coming out and it will then force it out the other end. Works well.
Old Nov 22, 2009 | 01:14 PM
fireaxxe's Avatar
fireaxxe
+1 great tip man works well.
Old Nov 22, 2009 | 01:27 PM
Faast Ed's Avatar
Faast Ed
Over greasing is just looking for trouble.
Being up with maintenance is a wonderful thing, but overkill sometimes ain't.
It's a neck bearing. It's spins at 0 rpm. Some grease, of course,.... but,......
McMurphy
EVO
Sep 22, 2013 10:34 PM
duluth
May 15, 2012 02:27 PM
hd4evr2008
May 16, 2010 08:29 AM
fishcop
May 12, 2009 10:07 PM
Trashy55
May 9, 2009 09:26 AM
