Somebody use belt dresser for their bike,i used that at work for big air conditionning drive motor it prevent the belt from slipping and protect the rubber maybe it's good for motorcycle belt???
Product Specification
Belt Dresser is used for cleaning and protecting transmission drives made of rubber, leather or synthetic material. when sprayed on the surface it prevents slippage, extends belt life and increase power transmission, it does not glaze the surface but develops friction and enhances grip. It helps in preserve leather and rubber belts, increasing working life and reliability.
Area of Application: Compressors, Pumps, Conveyours, Generators, Fans, Textile machinerys, Paper mills, farm equipment, Automotive Brake Pads and wear pads of trains
first this is a cogged belt and pulley system, so unless you are missing cogs, the belt won't slip if properly adjusted.
second if the pulleys (sprockets) and the belt are in good condition and properly adjusted, the belt will normally be silent and not require the lube.
Personally I haven't used lube since we quit using chains.
The drive belts on HD bikes are HTD Belt's. That stands for High Torque Delivery. They have pulley's that match the cogs on the belt. If properly adjusted they will last a long time. These belts do not stretch easily. anybody that knows these belts would not tell you to put lube on them. If they get loose they still won't slip. If they get too loose they will ride up on the cogs and break the belt, But they will not slip!!!
