Cam recommendations??
Old Nov 24, 2009 | 07:30 PM
customsoftail200's Avatar
customsoftail200
Default Cam recommendations??
I'm getting my parts together to do my 95 build. I have 10:1 pistons, hi flow heads w/ big valves and it's carbed.. Looking for a nice gear drive cam to get the big bagger going and have plenty of power on tap.. Any suggestions???
Old Nov 24, 2009 | 07:40 PM
BadPiggy's Avatar
BadPiggy
My 1st suggestion would be to check your crank runout before buying those gear drive cams.
Who did the heads?
What do they suggest?
Have you discussed cams with them?
Without forum members knowing who did the head work, there's not a lot to go on.
Old Nov 24, 2009 | 07:49 PM
customsoftail200
John Sachs did the head work, they have 1.9/1.6 valves in them with high lift springs. He recommended using a 55G cam, but I think that's a bit too aggressive for a bagger. I think I need more low end than top end.
I didn't check crank run out, is that an issue with these motors?? It's only got about 9K on it..
Old Nov 24, 2009 | 07:55 PM
davessworks's Avatar
davessworks
No brainer. SE 203. Practically the exact same set up I have. The service manager at my favorite dealer would likely say 204 cam however - but only for carb'd (which you have) - so pick your poison. Damn I love my FatBoy tune.
ps - yes I realize that these are not gear driven. Never saw the point - still don't.
Old Nov 24, 2009 | 07:57 PM
SEDELUXE's Avatar
SEDELUXE
with 10.1 comp go with a woods 6 cam .
r u in old bridge NJ??????? if you r i am in colonia
or go with a T-Man 525 or 590 cam.
Old Nov 24, 2009 | 07:59 PM
customsoftail200
Is there no real benefit for going gear drive?? They're a whole lot more expensive.. I heard you get longevity and a couple extra HP out of a gear drive vs. chain.. True or no? I ran a gear drive once in a race car I had, it seemed pretty good...
Old Nov 24, 2009 | 08:00 PM
customsoftail200
Yea, Old Bridge, NJ.. Colonia's not too far..
Old Nov 24, 2009 | 11:41 PM
Northside's Avatar
Northside
So you trust the guy to do your heads, but over rule his cam recommendation, and think you can get a better recommendation here? People will respond without even knowing the characteristics of the head work. If you trusted the guy with your heads trust him on the cam. Your parts have to compliment one another, a great torque cam closes early, run that with a lot of compression and you have problems. You need a cam that has enough timing to allow the heads to flow. Higher compression allows for longer duration cams without so much low end torque loss. Personally I use the cams my head work guy recommended.
Old Nov 25, 2009 | 12:29 AM
qtrracer's Avatar
qtrracer
Thumbs up
Great advice!
Old Nov 25, 2009 | 01:31 AM
bagman1's Avatar
bagman1
Couldnt have said it better myself.
JustDennis
Engine Mechanical Topics
Feb 3, 2015 03:15 PM
kwag245
Exhaust System Topics
Oct 31, 2010 07:03 PM
SeaHag
Aug 14, 2008 01:51 AM
charrell
Jul 10, 2007 12:33 AM
tiiiim2
11
Apr 15, 2007 12:41 AM
