Monkey Bagger Bars with Pics (Install)
Old Feb 13, 2011 | 08:45 AM
  #101
thecort's Avatar
thecort
Originally Posted by MassHD
You all have emails
Hey bro...thank you very much!
Old Feb 13, 2011 | 09:03 AM
  #102
thecort's Avatar
thecort
Ok, I read the instructions & they help out but they show a rounded top bend...I think I speak for most guys when I ask...Are there any suggestions on getting the connectors past the friggin double 45 degree top bend? Doesn't seem like the connectors will bend or fit to make the turn down the rest of the bar. Obviously it can be done. Just concerned about tearing/snapping the connector.
Old Feb 13, 2011 | 10:40 AM
  #103
xd.404life's Avatar
xd.404life
Hey Ya'll I'm a little late to this party but I am learning alot about these MBB, I am going to get a set with my income tax return. I am torn between the 10" and 12 " I am 5"9" and ride a 09 SG. I don't want to have to change any cables and I don't want my hands way above the fairing from what I can tell in photos is the 10" put your hands right at the top of the fairing and the 12" pretty much clear the fairing. Do you all find this to be true.
MassHD can I get a set of those instructions also-- troy.anthonysmith@yahoo.com
Thanks all,
Troy
Old Feb 13, 2011 | 10:56 AM
  #104
01glide's Avatar
01glide
Originally Posted by JsGlide
I am thinking about going with the monkey bars as well, not sure to run 12 or 14. What do you guys recommend? Can I also get a copy of the instructions, email is JRs73Stang@yahoo.com. Thanks for any help.
I went through the same choice. I ended up getting the 12s and as far as I'm considered they are perfect. I am 5'11" and with the stock seat my hands are just slightly above shoulders. The new feel is amazing, it is night and day from the stock bars. To each his own but I couldn't be more happy with my choice.
Old Feb 13, 2011 | 11:01 AM
  #105
01glide's Avatar
01glide
I ended up bending one of the connectors on mine and then broke it trying to get it straight. Luckily the local dealership had plenty in stock and they were only .42 cents. So I replaced 1 pin and had no trouble after that. Good Luck
Old Feb 13, 2011 | 05:39 PM
  #106
Geekzter's Avatar
Geekzter
What I did was split the amount of terminal wires so the hole group does not have to pass the bend at the same time. For example, 1/2 the wires will be as normal and the other 1/2 will be taped back. This way only 1/2 of the terminal pins will pass the bend the the renaming pins will pass the bend as you continue to pull the wire.
<br />
<br />
Old Feb 13, 2011 | 07:00 PM
  #107
JsGlide's Avatar
JsGlide
Thanks for the info, I think i am giong with the 12s. Really don't want my hands above my shoulders, I am 6'1 so I should be fine there with the 12s.
Old Feb 13, 2011 | 07:31 PM
  #108
rg_dave's Avatar
rg_dave
12's for sure.
Old Feb 13, 2011 | 09:39 PM
  #109
thecort's Avatar
thecort
Thanks for the tips guys. I'll give it another crack tomorrow.
Old Feb 14, 2011 | 08:04 PM
  #110
bobcat557's Avatar
bobcat557
any chance someone could send me the instructions to, please im getting the 12inch thanks bobcat557@comcast.net
