Getting the 12" monkeys for my 08 SG can someone PM me the instructions, that would be greatly appreciated. With the 12's did you guys go +8 on the wires???
I'd appreciate if you email me the instructions to gmduran1@verizon.net. Thanks in advance.
email sent
Originally Posted by BigGiant9
Would someone e mail me the PYO
Instructions for the monkey bars. Just received my 14" but no instructions.
My e mail is Bmehmke@***.net. Thank you
email sent
I'm putting on a set of 14 inch bars but the control wires AED too short. What do you use to connect the wires? Butt connectors?
Some type of crimp connector is advised, I used to solder & shrink wrap everything I did until I found that soldering makes the copper brittle. I've had soldered connections fail numerous times on a hard-tail chopper due to vibration.
Thanks!! Quick question do the supersize kits come with enough shrink tubing to cut off the stock tubing and replace with their tubing? I just purchased 14" monkey bars, and I am trying to make sure I will have all the right tools, and materials for the job. Also TexasSG you mentioned crimp connecting the extended wires instead of soldering, did you heat shrink after crimping? Thanks in advance.
