Monkey Bagger Bars with Pics (Install)
Old Sep 24, 2012 | 05:18 PM
  #651
TexasSG's Avatar
TexasSG
instructions sent to the four of you
Old Sep 24, 2012 | 09:41 PM
  #652
Bamboo's Avatar
Bamboo
Could I get copy also? tww-vt@myfairpoint.net
Thanks!
Old Sep 25, 2012 | 12:16 AM
  #653
fastwalkin's Avatar
fastwalkin
Could someone send me a copy of instructions/tips ? Thanks
vintageblade@gmail.com
Old Sep 25, 2012 | 03:57 PM
  #654
daryl_db's Avatar
daryl_db
Can someone please send me a copy of the instructions or tips?
db1454@gmail.com
Thank you!
Old Sep 25, 2012 | 04:19 PM
  #655
TexasSG's Avatar
TexasSG
Sent to the three of you, checked my sent file to see how many times that file has been emailed......just hit 100! That's a lot of Monkey Bars!!
Old Sep 25, 2012 | 05:38 PM
  #656
fastwalkin's Avatar
fastwalkin
TexasSG, thanks bro, with these instructions, my factory service manual and some of the youtube videos i've been watching I know I can do this...i'm leaning towards 10" Monkey Bagger Bars....
Old Sep 26, 2012 | 09:53 AM
  #657
joryyroj's Avatar
joryyroj
Stage I
Default Monkey Bagger Bar instructions?
Hi could someone please send me the instructions? Thank you so much in advance.
jorypai@gmail.com
Old Sep 26, 2012 | 03:10 PM
  #658
acchd's Avatar
acchd
Got the install done basically following Yaffe instructions. Harbor Freight was jackpot for materials! I used Carbon Steel Welding wire .0123" thin wire but strong won't break! I used .095 weedwacker line to thread welding wire. Used 2 sizes of shrink tubing 10mm x5M & 8mm x 5M. I used the 10mm shrink for left & right control wire bundles. Used the 8mm shrink for the TBW sensor bundle. I did cutout the infamous green TBW connector eliminating it and soldered and shrink wrapped. Picked up up bottle of Ideal Clear Glide at Lowes for lubing wire bundles and it worked out good.
Harbor Freight item numbers
10mm x 5mm Shrink wrap 98067 $2.99
8mm x 5mm Shirnk warp 98066 $2.99
Welding wire .023 4" spool 42915 $5.99
Here's the TBW green connector wiring elmination got from another forum .
Next is to draw a diagram of the two ends of the green connectors so you know which wires to connect when we cut off the connector. HD has split the wires coming from the sensor into two group with two different color shrink wraps:Black and Yellow. I will now refer to these as Black side wires and yellow side wires. Each side has a white wire, black wire, and red wire. This is what it looks like:
Here is how the wires will hook up.
Blue Wire------(Black Side) White Wire
Brown Wire----(Black Side) Red Wire
Black Wire-----(Black Side) Black Wire
Grey Wire-----(Yellow Side) Black Wire
Red Wire------(Yellow Side) Red Wire
Purple Wire----(Yellow Side) White Wire
Old Sep 28, 2012 | 07:45 AM
  #659
TexasSG's Avatar
TexasSG
jorypai@gmail.com
-sent
Old Oct 1, 2012 | 02:11 AM
  #660
sammiew's Avatar
sammiew
Could I get the instructions also please.
sammiedelanewilliams@gmail.com
