Accessory switch ?
Old Dec 22, 2009 | 10:38 PM
Bagger Bleu's Avatar
Bagger Bleu
That's a sweet looking rear end you got there Taylorized.
Old Dec 23, 2009 | 08:42 AM
wing_rdr's Avatar
wing_rdr
The rating for the accessory switch is 15 amp and there is a separate fuse in the main fuse box that controls the load in the switch circuit.
Old Dec 23, 2009 | 01:07 PM
cmhfguy's Avatar
cmhfguy
What's next, you going to ask him out on a date????
Old Dec 23, 2009 | 01:20 PM
Taylorized's Avatar
Taylorized
Thats Funny I'm married no dates.
Old Dec 23, 2009 | 02:57 PM
quigley's Avatar
quigley
Originally Posted by kjkustoms
2008 FLHX. Can anyone tell me , before I tear into it, the accessory switch on the inner fairing,beside the cruise control switch, I would like to connect my Heat Demons grip warmers to that switch, it is a dummy switch as far as I can tell, the light comes on but does nothing. How can I go about hooking something up to that? Any help is good.
I have a bunch of those plugs laying around. Pm me details of what you want and for a small fee I can make you a custom harness.
Quigley
Old Dec 23, 2009 | 03:40 PM
kurtlange's Avatar
kurtlange
the heat demons already have an on/off switch on the left h-bar controls. why another redudant switch??
Old Dec 23, 2009 | 04:42 PM
ezlife's Avatar
ezlife
Originally Posted by bagman1
Im not sure how much heated gear draws, but I dont remember seeing any 10A fuses, I thought they were all 15 or more.
If I remember right liner and gloves are 8.6 amps = 10A fuse
Old Dec 23, 2009 | 07:36 PM
cmhfguy's Avatar
cmhfguy
I just couldn't resist.. :-)
Old Dec 23, 2009 | 08:48 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
that plugg uses duetch conectors u can get crimp ons for like 20 cents apiece dont need the harley harness for 20$ there are 4 holes in the plugg use a tester to figure out the ground hot acc switch and ignition switch.
Old Dec 24, 2009 | 06:34 AM
quigley's Avatar
quigley
If you look at the plug under your seat you will see that each pin is numbered
1= 12V Ignition
2= Brake light
3= Acc switch on your dash
4= Ground
