Accessory switch ?
Old Aug 20, 2014 | 06:53 AM
  #31
sanman4ever's Avatar
sanman4ever
I wired my HD crash bar fog lamps to the switch. Used a relay, 15AMP fuse, and made my own deutsch connector. Found the procedure in the lighting electrical section.
Old May 9, 2015 | 01:21 AM
  #32
Magnus01's Avatar
Magnus01
6th Gear
Default Acc goes off when brakes applied??
I'm sure the correct answer is... "I did something wrong," but i hooked up a couple leds to the acc switch on my 2012 flhx. Whenever i apply the brakes, the lights go out. Any ideas??? Thanks!
Old May 9, 2015 | 07:41 AM
  #33
Buelligan666's Avatar
Buelligan666
You have your ground (negative) hooked to the wrong wire. The accessory plug under the seat has 4 wires.
Black - batt neg
orange/red - on with ignition
Red/yellow - brake
Orange - acc switch
Make sure your negative lead goes to the black wire or ground it to the battery -
FlatBlackGlide
Apr 18, 2012 05:43 PM
bobros
May 26, 2011 06:43 AM
HOGNOT
May 15, 2010 02:41 PM
quigley
Aug 29, 2009 12:16 AM
cooper57M
Mar 10, 2008 07:30 PM
