spark or gas?
Old Dec 30, 2009 | 12:03 AM
jacko1488's Avatar
jacko1488
Default spark or gas?
i have a 90 ultra with 42000 miles. starts, idles, and runs grate, but... at 80 or so if you ease in to the throtle, it all most feels as if you are bumping the brake, no miss and it speeds up. if you twist i wide open it goes, no prob. and some times at speed, 80 or so it will cough back in carb. one spit then its fine. any help out there? thanks for any direction you can send me in
Old Dec 30, 2009 | 12:31 AM
hog-doc's Avatar
hog-doc
What carb? Need to check what pilot jet you have and that your accelerator pump timing is correct. Air/fuel mixture screw set wrong can cause the spit too.
Old Dec 30, 2009 | 06:02 AM
rodeking's Avatar
rodeking
I had the same problem on an older carbed ultra. The rubber intake boots had cracked and thus an air leak. That is why it would spit and cough when given light throttle but would run o.k. at WOT.
Old Dec 30, 2009 | 06:06 AM
Notgrownup's Avatar
Notgrownup
I was gonna say...sounds like air is getting in there a bit...
Old Dec 30, 2009 | 07:11 AM
harley-jones's Avatar
harley-jones
Lean AFR.
Old Dec 30, 2009 | 09:56 AM
jacko1488's Avatar
jacko1488
Default thanks
thanks from the sound of things,yall dont think its spark eather. when i got it severiced the guy surposedly fixed leaks on both boots, guess i need to get some carb cleaner and check them myself. when it comes to jets and fule & air mix, i am at a lose, instead of guess work ill find someone that knows what they are doing there. Hey,thanks again
ellisem
Exhaust System Topics
Apr 19, 2017 06:14 AM
JohnnyC
EVO
42
Jul 14, 2016 09:23 AM
Night Train Rider
May 2, 2010 08:54 AM
slabman
Feb 28, 2009 02:39 PM
1unclejojo
Shovelhead
Jul 22, 2007 09:55 AM
