Changed for syn 3 to formula +
Old Jan 10, 2010 | 08:43 PM
bruce sg08's Avatar
bruce sg08
I used amsoil gear lube for the tranny at the last change, didn't notice any difference, klunk still there Will go to formula 1 next time around and see if that makes a difference
flipbel's Avatar
flipbel
The first gear clunk gone is the best.
Old Jan 10, 2010 | 08:54 PM
BigDaddyMike's Avatar
BigDaddyMike
I always ran Red Line in my previous Harleys. With this 09 I changed at 1000 miles to Redline and seemed to develop a slight tap in the front jug. At the suggestion of a good friend, who maintains a fleet of HDs for a motor squad, I changed to Formula+...Was I amazed..easier shifts, no clunk, ...I would have never done this but thought I'd give it a try. Since I change oil at 2500, there is really no need for ME to spend extra on synthetic...
Old Jan 10, 2010 | 08:58 PM
skratch's Avatar
skratch
mobil 1 15/50 in the engine ........... change at 5k intervals
formula + in the primary .............. change at 10k interval
75/140 gear oil in the tranny........... change at 10k interval
works for me, ymmv
Old Jan 11, 2010 | 09:57 AM
canuck pride's Avatar
canuck pride
Hey Big daddy Mike, are you talking about the motor oil or trans oil ? thanks
Old Jan 11, 2010 | 12:45 PM
iclick's Avatar
iclick
Motor oil in the primary is fine, but I would use fossil oil instead of synthetic. I've been using Castrol GTX 20w50 for the duration and recently had a tranny bearing replaced, which required removal of the inner-primary and all the components therein. That gave me an opportunity to install the SE compensator and to inspect all hardware in that area. The clutches were fine, as were the primary chain and tensioner, and at 33k miles we re-installed all the original hardware--except the compensator, of course. That told me the oil was doing its job and clutch operation has been excellent, so I'll stick with it. Some use ATF, which is also a good choice IMO, but I would stay away from synthetic oils of any type, as the clutches need some friction to operate properly and a high-tech oil is not needed in that location in any case.
Old Jan 11, 2010 | 02:12 PM
BigDaddyMike
I am using HD 20/50 in the engine and formula plus in tranny and primary..I love it..And it is cheap, if I buy it on sale by the case.
harleylay
Jul 9, 2017 05:47 PM
PostmanII
2014-2024 Touring Models
Jun 4, 2017 09:57 AM
Harley58
Sep 8, 2009 05:27 PM
street2007bob
May 17, 2008 08:55 AM
FLHDRIVER
Oct 27, 2007 08:41 AM
