touring recall
Old Jan 12, 2010 | 06:54 PM
big ears's Avatar
big ears
Default touring recall
Went to my dealership to get oil filter and primary gasket. They did recall on gas tank while I was looking around. Took about 20 minutes. Couldn't see what they did. Who cares? By the way is there a cheaper source for the oil filter. Are there subsutites that are as good or better?
Old Jan 12, 2010 | 06:58 PM
davessworks's Avatar
davessworks
I've usually avoided this answer but geez - do a search . . . tons of comments about alternate filters etc. Personally if it's just about saving money I don't get it . . . if you change the filter every 5k miles it's hardly worth trying to save a buck or two. Stock up from Chicago Harley or LSHD1
Old Jan 12, 2010 | 07:08 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by big ears
...By the way is there a cheaper source for the oil filter. Are there subsutites that are as good or better?
As suggested above, order 1 or 2 (or half a dozen if you need to) along with a gasket kit (derby cover and o-rings) thru some place like Chicago HD.
Not knowing what bike you have, take some time and read down through the appropriate threads on your machine. Then, while ordering filters and such, order the other stuff too.
While you might not need some things now, riding season is not that far away so order early and be ready.
Good luck!
Old Jan 12, 2010 | 07:12 PM
Clint55's Avatar
Clint55
Had one of these on my 62 Chevy 1/2 ton. Maybe they make an HD version.
Old Jan 12, 2010 | 07:47 PM
RKC2009's Avatar
RKC2009
Do you use the quilted?
Old Jan 12, 2010 | 07:49 PM
krazy3's Avatar
krazy3
I wuz wunderin' the same thing. I couldn't tell if it was 1 ply or not.
Old Jan 13, 2010 | 09:13 AM
big ears's Avatar
big ears
Good luck!
I'm down in Lousyana, rode to the dealer yesterday wich is 70 miles from me. It's always riding season after 10 am here unless its raining. Thank's for the answer. I'll check it out.
Old Jan 14, 2010 | 08:23 AM
huffhuff's Avatar
huffhuff
H-D filters are Purolator. List here is copied from earlier thread.
WARNING: All filters are not created equal even though they fit. Differences in bypass spring pressure and filter media could result in damage to your engine.
While it is advised to use the proper HD filter for your engine for proper filtration, here is a cross reference if you can't get a genuine part.
Size ---------Long--------------------- Short ----------------Extra Long -----------TC88 (long)
H-D - -------63805-80T (black)------381-80 (black)--------63812-90 (black)---------63798-99
-------------63795-77T (chrome)----63782-80 (chrome)----63813-90 (chrome)------(chrome)
AC/Delco -------------------------------------------------------- PF53 --------------PF53----
CCI(prem)---25-542 (black)--------------------------------5-220 (black)-------------22-250
-------------25-250 (chrome)------------------------------25-221 (chrome
CCI(revtech)-35-078------------------35-077--------------35-079-------------------35-074
Fram---------PH6022 (black)----------PH3614--------------PH3600 ----------------PH6022 (blk)
-------------PH6065A (Chr)--------------------------------PH6068 (chr)-----------PH6065A (CH)
Hastings---------------------------------------------------LF157
Motorcraft-------------------------------------------------FL793
NAPA------------------------------------------------------1348
Perform-------HD-2--------------------HD-3----------------HD-4
Purolator---------------------------------------------------L10241
STP-----------SMO-22
Wix--------------------------------------------------------51288, 51348, 51785
K&N--------------------------------------------------------------------------------171B (Blk)
------------------------------------------------------------------------------------171C (Chr)
Shacky73
General Topics/Tech Tips
25
Oct 24, 2020 08:10 PM
PennShovel
May 7, 2013 04:36 PM
Double3
Apr 8, 2010 09:23 AM
HoustonCH73
Shovelhead
Jul 5, 2009 10:03 PM
pilot1996
Oil Archive (no new posts)
19
Sep 5, 2005 07:49 PM
