All these cam threads lately...
Old Jan 14, 2010 | 07:09 PM
slick813's Avatar
slick813
Default All these cam threads lately...
have me half tempted to try one on my own. I have a 2010 Ultra with like 600 miles on it, it is currently on the lift out in the garage. I pulled the stock exhaust off to install V&H dresser duals and a SE air cleaner, I have a race tuner for it also.
I read atrain68's thread and some of the others, so I am thinking well it's already mostly apart, why not go ahead and pick up a set of 255s and go for it, the weather here in Ohio is going to suck for the next month or two, beside atrain68 lives close by. I have never met him but if I screw the thing up maybe I can beg him to come help me, decisions, decisions.
Old Jan 14, 2010 | 07:12 PM
Lawdawg's Avatar
Lawdawg
Same here, i have been thinking of doing the same thing. I think the 255 are the way to go.
Old Jan 14, 2010 | 07:22 PM
smokin joe's Avatar
smokin joe
i have done two set in different bikes (99 sg & 01 RK ) get a service book just in case you forget something not hard to do at all you will need to press cams out & in cam plate ( u can do it )
Old Jan 14, 2010 | 07:31 PM
user 8373900's Avatar
user 8373900
2010 the cams don't need pressed out/in the cam plate. 07 and newer have the new style cam plate.
Mark
Old Jan 14, 2010 | 07:32 PM
dawg's Avatar
dawg
On a 2010 you don't need to press the cams in or out of the plate. You would need to deal with the inner bearings still
Old Jan 14, 2010 | 07:35 PM
1931jamesw's Avatar
1931jamesw
Please explain why you dont have to press them in or out of the plate on 07 and newer.
Old Jan 14, 2010 | 07:40 PM
PhilM's Avatar
PhilM
Because there is no (physical) bearing in the camplate. THey use an "oil bearing".
Try a TMan 525 in those new motors!
Old Jan 14, 2010 | 07:41 PM
atrain68's Avatar
atrain68
Feel free to PM me if you get stuck. Glad to help out where I can.
Old Jan 14, 2010 | 07:54 PM
thewholehog's Avatar
thewholehog
PhilM, in your opinion/experience - does the Tman 525 need a bit of compression? Or do they work well in a completely stock top end?
Thanks.
Old Jan 14, 2010 | 08:36 PM
PhilM's Avatar
PhilM
Thanks.
They are designed as a "bolt-in" and work quite well that way. They are also able to work well, up to 10:1 CR.
Here's the blurb from TR's website:
"Chain drive bolt-in Cam, no head work required. Works well at 9.1 to 10.1 compression. A very good combination with flat top pistons and stock heads. Horsepower and torque increase with smooth ride."
http://tmanperformance.com/cams.htm
"Rideability" is excellent with them, properly tuned of course ~ additionally, they are very easy to tune!
Please don't drag me into another Squeal'n Beagle 255 debate.
My experience, advice, and recommendation is the TR525.
