When to replace bushings?
Old Jan 18, 2010 | 10:44 AM
arthur's Avatar
arthur
Question When to replace bushings?
Have a 2008 SG with 30,000 miles on it. Wondering when it is time to replace bushings. Does not seem to be riding the way it used to, especially on curves.
Have a bagger-brace and checked all tire tread/pressure etc.
Old Jan 18, 2010 | 11:21 AM
hog-doc's Avatar
hog-doc
Fork bushings? Those are the only suspension bushings left. They are usually through the teflon by 50K, I would recommend replacing them at 40K
If your asking about the swingarm they have been bearings since 02, and they are a large roller bearing. Not much wear.
Check the neck bearing adjustment!
Old Jan 18, 2010 | 12:23 PM
arthur's Avatar
arthur
Thanks, yep, was thinking about swing arm. Was looking at sta-bo
Old Jul 5, 2010 | 03:16 PM
phm6660's Avatar
phm6660
I would also recomend checking or just replacing all three motor mounts. Front is easy to inspect and if its showing signs of fatigue do all three especialy if you tend to drag a floor board more often than not and ride harder than average. New mounts staightened mine right out.
porschemann
Nov 24, 2024 10:46 AM
Stopit
2014-2024 Touring Models
37
Jul 7, 2019 12:05 PM
giacomo56
Jan 6, 2017 05:07 AM
kjelders
Jul 9, 2012 10:56 AM
Lpye
Apr 18, 2005 01:31 AM
