Were you guys able to snap the lens out from the front or did you have to do it from inside the fairing. I went to install my bezel and I got the bottom two tabs out but the top two don't seem to want to come out from the front. And I didn't want to press the issue and end up breaking it. Tried a small screwdriver wrapped with electrical tape but it seems like the tabs snap in there pretty good.
I installed mine in about 10 minutes, no no need to remove the fairing. When installing the new bezel, you may need to adjust the headlights, due to the fact the the new bezel snugs up against the headlight assembly and it may be adjusted out to prevent snapping the bezel in.
I take mine out from the front. I pop the two top tabs first using a very thin micro-tool flathead screw driver. You have to insert the screw driver, press down and in, then pull out. It's a Pain... took me several tries.
I think I know how to fix it.
The same thing happened to me, I had to adjust the headlight aiming screws until the bazel would snap in. If you're happy with the aim of you're headlights, you'll have to adjust all three screws evenly, moving the headlight assembly in until it allows the bezel to snap in.
