TWICHY STEERING
Old Jul 22, 2006 | 10:49 AM
BIG RUSS's Avatar
BIG RUSS
6th Gear
Default TWICHY STEERING
Please help???
As a new owner of a FLHTi 06 I find that above 70MPH that the steering becomes light & twichy.
I have just parted company with an un-fair softail which used to feel well planted at all speeds.
Dont know wether its the Bat Wing Fairing or a standard tyre fault.
Any help in this would be greatfully recieved.
BR
Old Jul 22, 2006 | 11:21 AM
DI75's Avatar
DI75
Default RE: TWICHY STEERING
Thats comforting !! LOL NOT !!
Old Jul 22, 2006 | 11:53 AM
bay13's Avatar
bay13
I was on the phone talking with the "true-track" people, (site sponsor) and he mentioned that if after installing the true track I need to take a higher speed run to see if I had handle bar wobble. True track has nothing to do with the handle bar wobble, they were just mentioning it cause they were aware of this addition Harley Davidson unique feature as well. They have a fix for that as well. It has to do with moving more weight to the rear tire. Would be worth calling and talking to them. HD will say it's normal, or no problem found.
Old Jul 22, 2006 | 05:11 PM
Lpye's Avatar
Lpye
Check your tire pressure and shock pressure. Too much pressure in the rear shocks will cause this as will a bad tire. I have ridden Electraglides for over 120,000 over the last 9 years. I have found this to be the case. I had a mismatched set of tires (Metzler on rear and Dunlop on front) and had that problem. I have also seen it with too much air in the rear shocks and tire pressure being off. I normally cruise on the interstate at 80 with out issue. I also had a tire out of balance one time that created some handling issues.
Old Jul 23, 2006 | 12:55 PM
waltr's Avatar
waltr
Yes what Luke said. Although I am waiting to pick up my '07 Ultra (my first Harley in 24 years) some things are the same no matter what you ride. If you lower rear shock preload more weight will be carried on the rear and less on the front. Increasing rear shock preload within reason will slow down the steering response because more weight is carried there. Check to see both rear shocks are set the same. Check tire pressure.
Old Jul 23, 2006 | 02:51 PM
BIG RUSS's Avatar
BIG RUSS
6th Gear
Thanks for your replies.All good advice and will take on board.
Luke may have hit it on the head,I picked up a puncture last week in the rear which ruined the tyre.Now running with a Avon Venom on the rear with an origanal HD Dunlop on the front.( before anyone asks i was in the middle of North Wales this was the only tyre they could supply ).But today we've been to a charity bash in Yorkshire where a 1000 or so bikes mainly Hogs rode across the Humber Bridge ( one of the largest suspention bridges in the world ) for cancer awarness and noteiced that at around 25-30 mph that the bars were shakeing slightly so front may need to be balanced.May be its a bit of both???.
As i've only had the bike for 2-3 weeks i'll put it back to the dealer to check it out.before using an independent bike shop who i know will be able to sort it out.
Old Jul 23, 2006 | 03:19 PM
nmfxstc's Avatar
nmfxstc
Just came off a 5K mile trip and pumped the tires up a bit (to 40 and 40) and noticed a lot more twitch! Dropped them to 36 F and 38 R and dropped shocks to 10# and it all smoothed out!
Old Jul 23, 2006 | 03:54 PM
BIG RUSS's Avatar
BIG RUSS
6th Gear
Thanks for that will give it a try.
BR
Old Jul 23, 2006 | 05:30 PM
Kahuna's Avatar
Kahuna
The air pressure in the front tire should be around 36psi, and 40 for the rear. 10lbs in the shocks are fine with passenger and saddlebags filled. With tour-pak, the shocks should be around 15lbs. More if you take more stuff.
ORIGINAL: nmfxstc
bama6977
May 8, 2010 10:39 PM
mongomark
May 3, 2010 02:17 AM
thegov3
Jul 7, 2009 11:03 PM
Sincecrazy
Oct 14, 2008 05:13 PM
jonah
Jan 23, 2008 03:24 PM
