oil pump
Old Feb 7, 2010 | 10:43 AM
coolhands03bagger's Avatar
coolhands03bagger
Default oil pump
Has anyone had any issues with the oil pump going out? If so, how many miles on the bike and what year. My dads 01 Standard has 53k on it and we were just wondering if we should replace it or just put it back in. Thanks, Luke
Old Feb 7, 2010 | 11:12 AM
nocarb's Avatar
nocarb
I had to have the one on my 02 replaced due to to cam bearing failure tearing it up. Not sure why you have pump out I'm guessing replacing chain tensioners. If you have it this far I would consider upgrading tensioners to hydraulic set up. This kit will have a high flow oil pump.
If you are on a budget I would think you would be fine with replacing bearings and tensioners. Judging by your current mileage the OEM set up should last you another 8-9 years.
Old Feb 7, 2010 | 11:39 AM
coolhands03bagger
Thanks. We are going with gear drive...so no tensioners. He just didn't want to spend the $350 if it really isn't necessary. If they usually go out at 100k, well, we will wait then.
Old Feb 7, 2010 | 11:47 AM
nocarb's Avatar
nocarb
If it was me I would replace pump just for piece of mind. But in all honesty maybe an inspection of rotors and housing you may be fine. If there is any scoring then replace.
Old Feb 7, 2010 | 11:48 AM
flhxkiller's Avatar
flhxkiller
I'd replace, did that to my 01RKC at around 40K when I put andrews gear drive and cams in. Believe I used one from a later bike that worked better according to the parts guy.
Old Feb 7, 2010 | 11:52 AM
coolhands03bagger
Thanks guys. This is what I'm looking for. Just need the PUSH to do it! A little bit of extra $$ can go a long way!
Did you guys replace it with a stock HD pump or something else?
Old Feb 7, 2010 | 11:57 AM
flhxkiller's Avatar
flhxkiller
I put the stock pump back in, was told by the local trusted engine guy that the newer design stock pump was fine. Less money too.
Old Feb 7, 2010 | 11:59 AM
1flhtk4me's Avatar
1flhtk4me
Went gear drive at 30000 miles and left the stock pump in.Now have 47000 miles and no pump issues.
Old Feb 7, 2010 | 12:33 PM
Flying Horse's Avatar
Flying Horse
The Harley oil pumps are a fairly stout part but if I'm doing a cam change I'd replace it with the new cam plate/pump kit. Its more money but it'll save more later if it does decide to go.
Old Feb 7, 2010 | 10:06 PM
coolhands03bagger
Thanks guys. I will be inspecting the pump tomorrow.
markwolula
Engine Mechanical Topics
13
Sep 6, 2016 09:20 PM
danroo
Oil Archive (no new posts)
Jan 15, 2015 04:43 AM
AnaChris
Mar 15, 2014 09:01 AM
sickhorse
Exhaust System Topics
14
May 26, 2011 10:17 AM
77Tulsa
Jul 10, 2007 04:18 PM
