Electrontic Throttle Control - Help Needed!
Old Feb 16, 2010 | 09:34 PM
Lemms's Avatar
Lemms
Default Electrontic Throttle Control - Help Needed!
Hey guys...
I am in the process of installing Heat Demons on my '08 Road King. I had to disconnect the ETC from behind the headlight and pull it out the right handle bar. Sounds easy enough. Not so much... I have the chrome housing that goes around the headlight and kind of rolls over the top of the handle bars and around the front forks. That really is a pain in the *** for this job.
I now have to get the ETC run back down the right handlebar and out into the headlight area to hook up again. Do I need to remove the chrome housing from around the headlight or am I able to do this without removing that? If I have to remove it, does anyone know the process for doing so? If I don't have to remove it, does anyone have any tricks for running the ETC back down it the headlight area? I am at a loss...
Thanks...
Old Feb 16, 2010 | 09:44 PM
dawg's Avatar
dawg
You should remove the headlight nacelle. It is outlined in the service manual how to remove the nacelle. If you don't have one, you should get one. However, kbore had a good write up on how to remove it HERE.
Old Feb 17, 2010 | 10:41 AM
Lemms's Avatar
Lemms
Thanks for the link dawg...
Going to pick a service manual up today. I don't think what I'm trying to do can be done without removing the headlight nacelle. This job is taking much longer than expected, but I'm sure that had I had a service manual before I started things would have went much quicker. And I have more updates that I plan to do before spring where the service manual is sure to help as well...
hogman6
Electrical/Lighting/Alarm
May 3, 2019 12:59 PM
dkleiner
Nov 22, 2017 09:23 AM
Moondogger
Milwaukee Eight (M8)
33
Sep 28, 2017 12:00 AM
RicMF
Jul 20, 2012 10:26 AM
Bacon_Grease
Mar 16, 2008 08:06 PM
