help flashers
Old Feb 17, 2010 | 08:49 PM
timeout's Avatar
timeout
Question help flashers
Does anyone no why my flashers start out at the right speed and then get faster and this is on both sides. Thanks
Old Feb 17, 2010 | 09:03 PM
Intrepid175's Avatar
Intrepid175
Generally speaking, if the turn signals flash unusually fast, it's because you've got a blown bulb. Failing that, and considering that you're getting the same symptoms on both sides, I'd say the flasher itself is going out. At least that's the first thing I'd check. I love diagnosing electrical problems!
Good luck,
Steve R.
Old Feb 17, 2010 | 09:40 PM
Potato_Potato's Avatar
Potato_Potato
As a first and easy step look for a bad bulb or a bulb is not seated properly. I'd take them all out and clean the contacts and add some dialectic grease. The TSM (or its variations) is looking for a certain current draw if a bulb is loose or blown it gets confused.
Old Feb 18, 2010 | 12:04 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Typically that's a bad ground. Usually, the lights each have their own ground but not sure in your case... Check your schematic.
Old Feb 18, 2010 | 07:21 AM
Heathen's Avatar
Heathen
I installed LED lights and had similar problem , plugged in load equalizer into harness and cured problem.
The Cheesehead
Touring Parts
Jun 24, 2012 06:39 AM
Fuzzy-1
Jun 21, 2012 12:03 PM
AR-15 DEUCE
Apr 25, 2009 05:18 PM
LagunaS2K
Dec 25, 2008 07:31 PM
clarkbaker1964
Electrical/Lighting/Alarm
Nov 12, 2008 06:14 PM
