There is nothing wrong with the stage 1 download when it comes to function. The biggest problem is the cost, at 150bucks its more cost effective to run a tuner that you can change when u want, and with the SERT costing more than $400 this is more expensive than the basic tuners also. However the HD stock ECU is designed to be programed and reprogrammed in order to adapt to whatever application you will be using for you bike i.e. fuel mileage or performance. The SERT is superior in that it uses the stock ECU to achieve a target AFR and most aftermarket tuners just blindly dump fuel into the engine not taking into consideration the close loop information that the O2 sensors are producing so you wast fuel when your cruising sometimes. The stage one download takes you from 14.6:1 to approximately 14:1 in the close loop range and goes anywhere from 13.5:1 to 12:7 outside 70 or 80% throttle so yes harleys actually run rich in these W.O.T. areas. If you look at any PCV map you will see the negative percentage numbers in these areas. The ideal setup would be to use the stage one download for the 103cu in. Even better than that would be to get the SERT super tuner and then you can enter the AFR values that you want at the dyno which would cost approximately 700bucks including dyno time.
Save your money on the PC, for a stock bike with a stage 1 kit it's over kill, all you do is waste gas. I ordered a kit from Fuelmoto, A/C, PC III pre-mapped and Jackpot mufflers, nice setup, nice sound, noticeable increase in performance. Had issues w/pcIII and Harley Thorttle by wire control, bike would shut off itermittenly at idle. Dumped the PCIII, Installed Xied from nightrider.com, no more problems, bike runs just as strong while getting better gas mileage. Like someone posted earlier, the factory closed loop system keeps AFR @ 14.6 or so, what the Xied does is go inline with your O2 sensor to fool the computer to think the bike is running leaner than it actually is, thus adding a little more gas to richen up your AFR back to what it thinks is 14.6. They work great, only cost $70 bucks. Also the harley closed loop control is in effect at idle up to about 4000 RPM or below 40 percent throttle position, after that it is open loop with a preset AFR of about 13:1 which is plenty for a stage 1 setup. There is a website HarleyTuning.com that explains the harley Fuel injection system very well.
JUST MY TWO CENTS.
Which tuner were you referring to that costs $300?? Just curious. I was under the impression the tuners were more costly than that.
Fuel Moto sells the PCV (Power Commander 5) for $300 with a double-warranty and lifetime maps and support. They install a map that was created from a dyno-tune at their facility on a like bike with like equipment. Do a search here for feedback reports from owners. There are other tuners that are even cheaper, but are feature-deficient by comparison.
What tuners "dump fuel into the engine"? Could you explain this phenomenon and name a few that do this?
None of my PCIII or PCV maps ('07 FLHX) have ever shown any negatives in this range (except one -1 in my current map), mostly single- and double-digit positives up to 16% above 60% TP.
You can enter AFR values in the closed-loop area, up to about 60% TP, and only down to about 14.2:1. You can't go lower because of the inherent limitations of these narrow-band sensors. The PCV with Auto-Tune, however, uses wide-band sensors and works in closed-loop throughout the RPM/TP range. It's able to tune between about 11:1 and 16:0, far outside the usable AFR range of most (all?) street vehicles. It costs $600 (PCV and AT together) and doesn't require a dyno-tune since AFR's are tuned on the fly to your specs.
You're the first person I've seen to report better mileage when using XIED's.
They will provide AFR's down to 14.2 in closed-loop mode, no lower because of the limitations of the narrow-band O2 sensors, but will not change anything above ~50% TP (open-loop). If you plan on keeping your stock AC you can run XIED's, but once a free-flowing AC is installed you are advised to either install a real tuner or go for the HD Stage 1 download. By the time you've done all that you've spent enough for a real tuner.
BTW, your issues with the PCIII are an anomaly and shouldn't be considered normal. Did Fuel Moto replace the unit or offer to do so?
That site isn't working for me right now. Where did you get your info on a "preset AFR of about 13:1"? Are you saying your bike runs 13:1 in open-loop with a stock ECM?
I used to recommend the Xied's for an easy and quick solution to the heat issue but then I found out they cause the O2 sensors to fail prematurely. That pretty much takes away any cost benefit from them. Plus they only run in closed loop while a genuine tuner, like TTS, works all the time. Not to mention all the possible adjustments that can be made.
The 103 download does make sense for a TC96. Probably not quite legal for a dealership to do but I can see the benefit.
If I ain't mistaken I thought I've seen post on here where it was said that the Harley download don't change fuel that it only changes rev limiter and advances spark
