Two map success
Old Feb 28, 2010 | 12:35 PM
acchd's Avatar
acchd
I installed $3 SPST(single pole single throw) submini toggle switch from Radio Shack(p/n 275-0612). Mounted it on right frame below seat(above plug wires) where there's a existing hole on '09's. Haven't had a chance yet to do a A/B mpg compare yet.
Old Feb 28, 2010 | 07:12 PM
lock55's Avatar
lock55
I wouldn't think there is a problem, if wet it just shorts out to the closed position, there is no power to worry about. I think where i have it there is enough heat to dry out fast. The switch is enclosed factory wired, the splices are protected under the frame splice plate.
Old Feb 28, 2010 | 09:07 PM
rkoivisto's Avatar
rkoivisto
Default Switch
It's very unlikely that the switch getting wet would cause any problems. As stated above, the worst that would happen is the wrong map would be running. doubtful that it would do that though.
An alternate way to switch is to use the Acc switch and run the power through a relay. I did that cause it took absolutely no altering of the wiring or drilling holes. If you run heated gear, you just make sure your MPG map is active when the switch is off. That way if it's cold enough to run heated gear, you won't be worried about the bike running hot, so you unplug the relay and plug in the heated gear.
Old Sep 22, 2010 | 03:52 PM
DrPlastic's Avatar
DrPlastic
How do you actually wire the switch to the PC-V. Do you hook each of the switch terminals to the two map hook ups on the PC-V? With the switch on which map is enabled?
Old Sep 22, 2010 | 04:25 PM
KutenFLHX's Avatar
KutenFLHX
I installed a switch using a stock Harley ACC switch and wired it so that the led on the switch still works. Required installing either a SPST (map 2 active when on) or a SPDT (map 1 active when on) relay. I did a write-up of my install with some diagrams and pictures here.
LazySundays
Jul 9, 2019 09:47 AM
Weeboy1
Jun 10, 2015 02:49 PM
supra0001
Apr 16, 2013 05:39 PM
1sweetglide08
Nov 27, 2009 08:10 AM
flhtupser
Apr 28, 2009 10:01 PM
