would this make speedometer wrong?
Old Mar 5, 2010 | 11:36 PM
Bay225's Avatar
Bay225
Default would this make speedometer wrong?
Going from stock 16 inch tires and wheels to 18 inch on ultra classic. Will this effect speedometer and the odometer? I Know alot of people upgrade to 18 inch and I have never heard of this to be a problem.
Old Mar 5, 2010 | 11:40 PM
PistonPuller's Avatar
PistonPuller
Very negligible
Old Mar 6, 2010 | 02:36 AM
Watch Guy's Avatar
Watch Guy
Default It could be as much as
5 mph. and it will show slower than you're actually going.
Old Mar 6, 2010 | 02:41 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Definitely will affect.
Old Mar 6, 2010 | 06:49 AM
cmhfguy's Avatar
cmhfguy
What will affect it is the outside circumference of the tire. Compare outside circumference (mounted and inflated on a rim) of old and new tires and that will tell you the percentage off the speedo and odo will be.
If you divide the new circ by the old then multiply the answer by 100, you will get a number in the 100s.. say for example you get 108.12. That means you will have to go an indicated on your speedo 108 mph on the new tire in order to be REALLY going only 100.
Old Mar 6, 2010 | 07:03 AM
Dalton's Avatar
Dalton
All the answers above may be correct or incorrect. It all depends on tire circumference. I went from 16s to 18s on my Road King and was careful in selecting low profile 18" tires that were almost identical to the circumference of the 16s. No speedo change. If yo do go to larger circumference tires, then the speedo is giong to read slow. If you do this , I have a Baker VSS calibrator for sale. It plugs in-line to the VSS and can adjust to get the speedo spot on. Shoot me a PM if you need it.
Old Mar 6, 2010 | 08:36 AM
Bay225's Avatar
Bay225
Waiting for custum shop to return my original 16 in dunlops and stock wheels so I can measure against the new 18 inch wheel and metzler tires. The metzler tires seem to be a lower profile.
Thanks to everyone for the very valueable info. John
Old Mar 6, 2010 | 04:12 PM
Glenn W's Avatar
Glenn W
like CMH said, and keep in mind it's a % of difference-not a set MPH at any speed. If it's 5% different it'd be 5mph at 100 but only 2-1/2mph at 50.
Texas Rapier
Wheels/Tires
20
Mar 23, 2020 09:05 PM
seanl
Wheels/Tires
May 2, 2017 11:10 PM
WoodrowWillson
Shovelhead
Nov 7, 2012 02:22 PM
sonny08
Feb 10, 2011 09:30 PM
crusteel45
Feb 16, 2006 11:52 PM
