Help with Snap Ring Replacement on Levers
Old Mar 14, 2010 | 10:58 AM
nextorion's Avatar
nextorion
Default Help with Snap Ring Replacement on Levers
Just put a new set of levers on (chrome brake and clutch). Used a pair of snap ring pliers to get the original snap rings off. Immediately noted that I should have bought two new rings as replacements as one became distorted when I removed it. Tried to put the good one back on using the snap ring pliers and I apparently distorted that one in the process too (plus I was not able to get it back into place anyway). Will buy several new ones, but I am looking for suggestions/tips as to how to best get the new ones on without ruining them. Assume that maybe I should not use the snap ring pliers for the reinstall? Any help appreciated.
Old Mar 14, 2010 | 11:31 AM
soos's Avatar
soos
Using the right size pliers is a must and not saying that you didn't. As for distorting the rings, you can easily reshape them if you haven't twisted them too far out of shape. Once in the groove they should conform to the groove. As for not using the pliers to reinstall the rings, it can be a Royal PITA.
Old Mar 14, 2010 | 11:37 AM
cuda67bnl's Avatar
cuda67bnl
I've always just pushed them on with my fingers on the levers. Not hard at all.
Old Mar 14, 2010 | 11:43 AM
PistonPuller's Avatar
PistonPuller
I use snap ring pliers all the time. The trick is to open the rings just enough to get it on the pin. When you open them up too much is when they distort.
Old Mar 14, 2010 | 11:52 AM
nocarb's Avatar
nocarb
I replace them when I reinstall. I use snap ring piers to install. I put snap ring on pliers put snap ring up to pin and just open snap ring enough to get on pin and slide the rest of the way by hand.
Old Mar 14, 2010 | 12:13 PM
Leftcoaster's Avatar
Leftcoaster
Mine always seem to distort even when I'm careful not to over-expand them when removing. I've never lost or replaced one but dropping one on the floor makes for some real fun. I close them back to their original size before re-installing the clip and I make sure they're closed all the way afterward by pinching the ends together with needle-nose pliers. Note: It's VERY easy to pinch a nice blood blister into your finger while doing this part (mine's healed now).
Old Mar 14, 2010 | 04:54 PM
Punjabi Rider's Avatar
Punjabi Rider
+ 1 just use my fingers too snap tool too high tech and takes too long any thing takes too long I lost interest in it.
Old Mar 14, 2010 | 05:01 PM
RKKY's Avatar
RKKY
Best thing I have found was a cheap 4 piece set of small snap ring pliers off the Snap-On truck. Cost like $7.95 and 2 sets have a 90 degree tip (the other 2 are straight). They are the perfect size for the lever snap rings and the angle makes it easy to reach them even if the t/s are on the bars.
YodaddyKeith
Oct 23, 2019 02:55 PM
VA_Larry
Feb 2, 2017 08:58 AM
rounder
Sep 18, 2015 03:04 PM
chopperguytampa
Oct 12, 2014 08:49 AM
bfrmbama
Exhaust System Topics
May 12, 2010 11:57 AM
